Can someone help out a transcoding newbie. I understand transcoding, but what I don’t understand is the following from the Plex manual.
When hardware acceleration is being used, you should see (hw) next to the Video format as shown above.
- The status text will show
Video Transcoding [FORMAT] (hw) to [FORMAT] (hw). - The first
(hw)indicates that hardware-accelerated video decoding is being used. Only certain video formats are supported for this. - The second
(hw)indicates that hardware-accelerated video encoding is being used. - Depending on the video file and the server hardware, hardware acceleration can be used for decoding, encoding, or both.
The part that has me stumped is decoding and encoding the it appears that you could, in theory have a file that supports HW “decoding” BUT NOT “encoding”. I assumed that if the GPU supported either, it would support both.
So, looking for a bit of detail around the split that a file could be decoded, but not encoded, or I guess vice versa also.
Thanks for any support.
