I installed a new router and now Plex cannot be found on my NAS Synology system
Your log files are showing me that it’s working just fine.
I think, with all the moving of files you did, something got corrupted in the Plex share.
Tomorrow, Take your time, go through each step; understand what each step is about rather than doing blindly.
I didn’t move any files before though. Set new router up, had to change the IP of my NAS, Plex would work on my iPhone and smart TVs, but remotely and on the computers it wouldn’t find the media server. Hopefully starting it from scratch fixes it.
remember to restart DSM
You will also likely have to re-home the apps.
They will be looking for the old server ID.
Sometimes, it’s easier to re-install the app than fuss with it.
Just some extra info. My DSM IP was originally 10.0.1.19, but with my new router I cannot add the range to it. I thought that was the issue, Obviously not. I am starting the new install of Plex now. Thank you.
So it is set up, but it is not letting me claim the server. I click it and it says there was an error.
What’s the error? There are several possible errors.
wasn’t an error number, just said cannot claim server. I was reading that the IP address isn’t private so I changed my 1 to a 0 to see if that will help. I am about to change the IP on the DSM now.
now it says there was a problem signing into Plex
Logs-2.zip (1.4 MB)
Your network is a mess.
Jan 12, 2021 09:03:14.652 [0x7f430035b740] DEBUG - NetworkInterface: Notified of network changed (force=0)
Jan 12, 2021 09:03:14.652 [0x7f42f4e11700] DEBUG - PublicAddressManager: Obtaining public IP.
Jan 12, 2021 09:03:14.653 [0x7f42f4e11700] DEBUG - HTTP requesting GET http://plex.tv/pms/:/ip
Jan 12, 2021 09:03:14.653 [0x7f42f4835700] DEBUG - NAT: UPnP, attempting port mapping.
Jan 12, 2021 09:03:14.653 [0x7f430035b740] DEBUG - Detected primary interface: 0.0.0.0
Jan 12, 2021 09:03:14.653 [0x7f430035b740] DEBUG - Network interfaces:
Jan 12, 2021 09:03:14.653 [0x7f430035b740] DEBUG -  * 1 lo (127.0.0.1) (loopback: 1)
Jan 12, 2021 09:03:14.653 [0x7f430035b740] DEBUG -  * 3 eth0 (192.168.0.240) (loopback: 0)
Jan 12, 2021 09:03:14.653 [0x7f430035b740] DEBUG -  * 4 eth1 (169.254.163.205) (loopback: 0)
Jan 12, 2021 09:03:14.653 [0x7f430035b740] DEBUG -  * 1 lo (::1) (loopback: 1)
Jan 12, 2021 09:03:14.653 [0x7f430035b740] DEBUG -  * 3 eth0 (2603:6000:9843:6e0f:211:32ff:fe8c:900) (loopback: 0)
Jan 12, 2021 09:03:14.653 [0x7f430035b740] DEBUG -  * 3 eth0 (fe80::211:32ff:fe8c:900%eth0) (loopback: 0)
Jan 12, 2021 09:03:14.653 [0x7f430035b740] DEBUG - Creating NetworkServices singleton.
Jan 12, 2021 09:03:14.653 [0x7f430035b740] DEBUG - NetworkServices: Initializing...
Jan 12, 2021 09:03:14.653 [0x7f430035b740] DEBUG - NetworkService: Creating new service.
Jan 12, 2021 09:03:14.653 [0x7f430035b740] DEBUG - NetworkService: Got notification of changed network (first change: 1)
Jan 12, 2021 09:03:14.653 [0x7f430035b740] DEBUG - NetworkService: Quick dispatch of network change.
Jan 12, 2021 09:03:14.654 [0x7f430035b740] DEBUG - Starting HTTP server.
Jan 12, 2021 09:03:14.654 [0x7f430035b740] DEBUG - Running server...
Jan 12, 2021 09:03:14.654 [0x7f430035b740] DEBUG - Waiting for server condition to be signaled.
Jan 12, 2021 09:03:14.654 [0x7f42f4835700] DEBUG - NAT: UPnP, found device <http://192.168.0.240:5000/ssdp/desc-DSM-eth0.xml> with private address <192.168.0.240>
Jan 12, 2021 09:03:14.654 [0x7f42f4835700] DEBUG - NAT: UPnP, not an IGD: <http://192.168.0.240:5000/ssdp/desc-DSM-eth0.xml>.
Jan 12, 2021 09:03:14.654 [0x7f42ded3b700] DEBUG - Network change for advertiser.
Jan 12, 2021 09:03:14.654 [0x7f42ded3b700] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:32414
Jan 12, 2021 09:03:14.655 [0x7f42ded3b700] ERROR - NetworkService: Couldn't join multicast group: set_option: No such device
Jan 12, 2021 09:03:14.655 [0x7f42de471700] DEBUG - Plex Tuner Service starting.
Jan 12, 2021 09:03:14.655 [0x7f42df317700] DEBUG - NetworkInterface: Watching for changes on the interfaces.
Jan 12, 2021 09:03:14.655 [0x7f42de183700] DEBUG - HttpServer: Set up a thread pool with 2 threads.
Jan 12, 2021 09:03:14.655 [0x7f42de183700] DEBUG - Running database fix-ups.
Jan 12, 2021 09:03:14.655 [0x7f42ded3b700] ERROR - Error broadcasting message: send_to: Network is unreachable
Jan 12, 2021 09:03:14.655 [0x7f42ded3b700] DEBUG - Network change for advertiser.
Jan 12, 2021 09:03:14.670 [0x7f42f50ff700] DEBUG - Completed: [127.0.0.1:57934] 200 GET / (5 live) GZIP 9ms 1189 bytes
Jan 12, 2021 09:03:14.672 [0x7f42f53ed700] DEBUG - Completed: [127.0.0.1:57936] 200 GET / (5 live) GZIP 11ms 1189 bytes
Jan 12, 2021 09:03:14.672 [0x7f42f53ed700] DEBUG - Completed: [127.0.0.1:57938] 200 GET /servers (5 live) GZIP 10ms 491 bytes
Jan 12, 2021 09:03:14.673 [0x7f42de75f700] ERROR - Error issuing curl_easy_perform(handle): 6
Jan 12, 2021 09:03:14.673 [0x7f42de75f700] WARN - HTTP error requesting GET https://plex.tv/api/photos/profile (0, No error) (Could not resolve host: plex.tv)
Jan 12, 2021 09:03:14.673 [0x7f42de75f700] ERROR - AutoTagging: unable to retrieve updated word lists
Jan 12, 2021 09:03:14.673 [0x7f42de183700] ERROR - Error issuing curl_easy_perform(handle): 6
Jan 12, 2021 09:03:14.673 [0x7f42de183700] WARN - HTTP error requesting GET https://plex.tv/api/v2/release_channels?X-Plex-Token=xxxxxxxxxxxxxxxxxxxxd not resolve host: plex.tv)
Jan 12, 2021 09:03:14.673 [0x7f42de183700] WARN - [AutoUpdateRequestHandler] Couldn't get update channels. Trying again soon.
Jan 12, 2021 09:03:14.674 [0x7f42de183700] DEBUG - HTTP requesting GET https://plex.tv/api/v2/user/privacy?X-Plex-Token=
Jan 12, 2021 09:03:14.678 [0x7f42de183700] ERROR - Error issuing curl_easy_perform(handle): 6
Jan 12, 2021 09:03:14.678 [0x7f42de183700] WARN - HTTP error requesting GET https://plex.tv/api/v
  1. PMS sees the IP address of the Synology (192.168.0.240)
  2. It cannot get out to the internet (notice the Detected primary interface: 0.0.0.0)
My suggestion to you - Use DHCP (router assigned IP addresses) until you sort this out.
Do this for the Mac and the Synology. Restart both after making the change.
192.168.0.x and 192.168.1.x are both “Private Networks” . Changing “1” to “0” was moot.
I changed my router to be 10.0.0.1 and that range, switched the NAS to DHCP, now working on Plex and it say says this A problem has been detected with a core component of Plex Media Server.
Ok… that makes more sense and is resolvable.
  1. Uninstall the package
  2. Restart DSM
  3. Delete the folder Library in the Plex shared folder.
  4. Install the package
  5. Allow it to start up. (wait 2-3 minutes after you install for those data structures to create)
  6. Now open PMS.
The error you got will appear if we try to open PMS before it’s ready when installing.
It’s a timeout error. There’s nothing really wrong other than it’s not ready yet. (the browser didn’t know what’s happening. It only knew it didn’t get a response in time)
I had to change my DNS and then it worked. The DNS on my Server was not the same on my router
