Many thanks mikec_pt, changing that one line fixed everything!
export LD_LIBRARY_PATH="%%PREFIX%%/lib/compat:${SCRIPTPATH}"
export LD_LIBRARY_PATH="${SCRIPTPATH}/lib"
Use sh -x /usr/local/etc/rc.d/plexmediaserver (or whatever is the path to the rc.d file) this will make it “verbose” and should HL where the issue is coming from.
Cool didn’t know about that. Never done shell script debugging before, should those lines at the end be missing a + character at the beginning of the line?
I tried rolling back to an earlier snapshot, realized I hadn’t ticked recursive on my periodic snapshot tasks…
Better to find out now with a plex issue and not something more important.
root@plexmediaserver_1:/usr/local/etc/rc.d # sh -x plexmediaserver
+ . /etc/rc.subr
+ : 11441
+ export RC_PID
+ [ -z '' ]
+ _rc_subr_loaded=YES
+ SYSCTL=/sbin/sysctl
+ SYSCTL_N='/sbin/sysctl -n'
+ SYSCTL_W=/sbin/sysctl
+ ID=/usr/bin/id
+ IDCMD='if [ -x /usr/bin/id ]; then /usr/bin/id -un; fi'
+ PS='/bin/ps -ww'
+ /bin/ps -ww -p 11441 -o jid=
+ JID=0
+ _rc_namevarlist='program chroot chdir env flags fib nice user group groups prepend'
+ _rc_subr_loaded=:
+ name=plexmediaserver
+ rcvar=plexmediaserver_enable
+ load_rc_config plexmediaserver
+ local _name _rcvar_val _var _defval _v _msg _new _d
+ _name=plexmediaserver
+ false
+ [ -r /etc/defaults/rc.conf ]
+ debug 'Sourcing /etc/defaults/rc.conf'
+ . /etc/defaults/rc.conf
+ rc_info=NO
+ rc_startmsgs=YES
+ rcshutdown_timeout=90
+ early_late_divider=FILESYSTEMS
+ always_force_depends=NO
+ apm_enable=NO
+ apmd_enable=NO
+ apmd_flags=''
+ ddb_enable=NO
+ ddb_config=/etc/ddb.conf
+ devd_enable=YES
+ devd_flags=''
+ kldxref_enable=NO
+ kldxref_clobber=NO
+ kldxref_module_path=''
+ powerd_enable=NO
+ powerd_flags=''
+ tmpmfs=AUTO
+ tmpsize=20m
+ tmpmfs_flags=-S
+ varmfs=AUTO
+ varsize=32m
+ varmfs_flags=-S
+ populate_var=AUTO
+ cleanvar_enable=YES
+ local_startup=/usr/local/etc/rc.d
+ script_name_sep=' '
+ rc_conf_files='/etc/rc.conf /etc/rc.conf.local'
+ zfs_enable=NO
+ gptboot_enable=YES
+ gbde_autoattach_all=NO
+ gbde_devices=NO
+ gbde_attach_attempts=3
+ gbde_lockdir=/etc
+ geli_devices=''
+ geli_tries=''
+ geli_default_flags=''
+ geli_autodetach=YES
+ root_rw_mount=YES
+ fsck_y_enable=NO
+ fsck_y_flags=''
+ background_fsck=YES
+ background_fsck_delay=60
+ netfs_types='nfs:NFS oldnfs:OLDNFS smbfs:SMB'
+ extra_netfs_types=NO
+ hostname=''
+ hostid_enable=YES
+ hostid_file=/etc/hostid
+ nisdomainname=NO
+ dhclient_program=/sbin/dhclient
+ dhclient_flags=''
+ background_dhclient=NO
+ synchronous_dhclient=NO
+ defaultroute_delay=30
+ defaultroute_carrier_delay=5
+ netif_ipexpand_max=2048
+ wpa_supplicant_program=/usr/sbin/wpa_supplicant
+ wpa_supplicant_flags=-s
+ wpa_supplicant_conf_file=/etc/wpa_supplicant.conf
+ firewall_enable=NO
+ firewall_script=/etc/rc.firewall
+ firewall_type=UNKNOWN
+ firewall_quiet=NO
+ firewall_logging=NO
+ firewall_logif=NO
+ firewall_flags=''
+ firewall_coscripts=''
+ firewall_client_net=192.0.2.0/24
+ firewall_simple_iif=ed1
+ firewall_simple_inet=192.0.2.16/28
+ firewall_simple_oif=ed0
+ firewall_simple_onet=192.0.2.0/28
+ firewall_myservices=''
+ firewall_allowservices=''
+ firewall_trusted=''
+ firewall_logdeny=NO
+ firewall_nologports='135-139,445 1026,1027 1433,1434'
+ firewall_nat_enable=NO
+ firewall_nat_interface=''
+ firewall_nat_flags=''
+ dummynet_enable=NO
+ ip_portrange_first=NO
+ ip_portrange_last=NO
+ ike_enable=NO
+ ike_program=/usr/local/sbin/isakmpd
+ ike_flags=''
+ ipsec_enable=NO
+ ipsec_file=/etc/ipsec.conf
+ natd_program=/sbin/natd
+ natd_enable=NO
+ natd_interface=''
+ natd_flags=''
+ ipfilter_enable=NO
+ ipfilter_program=/sbin/ipf
+ ipfilter_rules=/etc/ipf.rules
+ ipfilter_flags=''
+ ipnat_enable=NO
+ ipnat_program=/sbin/ipnat
+ ipnat_rules=/etc/ipnat.rules
+ ipnat_flags=''
+ ipmon_enable=NO
+ ipmon_program=/sbin/ipmon
+ ipmon_flags=-Ds
+ ipfs_enable=NO
+ ipfs_program=/sbin/ipfs
+ ipfs_flags=''
+ pf_enable=NO
+ pf_rules=/etc/pf.conf
+ pf_program=/sbin/pfctl
+ pf_flags=''
+ pflog_enable=NO
+ pflog_logfile=/var/log/pflog
+ pflog_program=/sbin/pflogd
+ pflog_flags=''
+ ftpproxy_enable=NO
+ ftpproxy_flags=''
+ pfsync_enable=NO
+ pfsync_syncdev=''
+ pfsync_syncpeer=''
+ pfsync_ifconfig=''
+ tcp_extensions=YES
+ log_in_vain=0
+ tcp_keepalive=YES
+ tcp_drop_synfin=NO
+ icmp_drop_redirect=NO
+ icmp_log_redirect=NO
+ network_interfaces=auto
+ cloned_interfaces=''
+ sppp_interfaces=''
+ fec_interfaces=''
+ ppp_enable=NO
+ ppp_program=/usr/sbin/ppp
+ ppp_mode=auto
+ ppp_nat=YES
+ ppp_profile=papchap
+ ppp_user=root
+ hostapd_enable=NO
+ syslogd_enable=YES
+ syslogd_program=/usr/sbin/syslogd
+ syslogd_flags=-s
+ altlog_proglist=''
+ inetd_enable=NO
+ inetd_program=/usr/sbin/inetd
+ inetd_flags='-wW -C 60'
+ iscsid_enable=NO
+ iscsictl_enable=NO
+ iscsictl_flags=-Aa
+ hastd_enable=NO
+ hastd_program=/sbin/hastd
+ hastd_flags=''
+ ctld_enable=NO
+ local_unbound_enable=NO
+ kdc_enable=NO
+ kdc_program=/usr/libexec/kdc
+ kdc_flags=''
+ kadmind_enable=NO
+ kadmind_program=/usr/libexec/kadmind
+ kpasswdd_enable=NO
+ kpasswdd_program=/usr/libexec/kpasswdd
+ kfd_enable=NO
+ kfd_program=/usr/libexec/kfd
+ kfd_flags=''
+ ipropd_master_enable=NO
+ ipropd_master_program=/usr/libexec/ipropd-master
+ ipropd_master_flags=''
+ ipropd_master_keytab=/etc/krb5.keytab
+ ipropd_master_slaves=''
+ ipropd_slave_enable=NO
+ ipropd_slave_program=/usr/libexec/ipropd-slave
+ ipropd_slave_flags=''
+ ipropd_slave_keytab=/etc/krb5.keytab
+ ipropd_slave_master=''
+ gssd_enable=NO
+ gssd_program=/usr/sbin/gssd
+ gssd_flags=''
+ rwhod_enable=NO
+ rwhod_flags=''
+ rarpd_enable=NO
+ rarpd_flags=-a
+ bootparamd_enable=NO
+ bootparamd_flags=''
+ pppoed_enable=NO
+ pppoed_provider='*'
+ pppoed_flags='-P /var/run/pppoed.pid'
+ pppoed_interface=fxp0
+ sshd_enable=NO
+ sshd_program=/usr/sbin/sshd
+ sshd_flags=''
+ ftpd_enable=NO
+ ftpd_program=/usr/libexec/ftpd
+ ftpd_flags=''
+ amd_enable=NO
+ amd_program=/usr/sbin/amd
+ amd_flags='-a /.amd_mnt -l syslog /host /etc/amd.map /net /etc/amd.map'
+ amd_map_program=NO
+ autofs_enable=NO
+ automount_flags=''
+ automountd_flags=''
+ autounmountd_flags=''
+ nfs_client_enable=NO
+ nfs_access_cache=60
+ nfs_server_enable=NO
+ oldnfs_server_enable=NO
+ nfs_server_flags='-u -t'
+ nfs_server_managegids=NO
+ mountd_enable=NO
+ mountd_flags=-r
+ weak_mountd_authentication=NO
+ nfs_reserved_port_only=NO
+ nfs_bufpackets=''
+ rpc_lockd_enable=NO
+ rpc_lockd_flags=''
+ rpc_statd_enable=NO
+ rpc_statd_flags=''
+ rpcbind_enable=NO
+ rpcbind_program=/usr/sbin/rpcbind
+ rpcbind_flags=''
+ rpc_ypupdated_enable=NO
+ keyserv_enable=NO
+ keyserv_flags=''
+ nfsv4_server_enable=NO
+ nfscbd_enable=NO
+ nfscbd_flags=''
+ nfsuserd_enable=NO
+ nfsuserd_flags=''
+ timed_enable=NO
+ timed_flags=''
+ ntpdate_enable=NO
+ ntpdate_program=/usr/sbin/ntpdate
+ ntpdate_flags=-b
+ ntpdate_config=/etc/ntp.conf
+ ntpdate_hosts=''
+ ntpd_enable=NO
+ ntpd_program=/usr/sbin/ntpd
+ ntpd_config=/etc/ntp.conf
+ ntpd_sync_on_start=NO
+ ntpd_flags='-p /var/run/ntpd.pid -f /var/db/ntpd.drift'
+ ntp_src_leapfile=/etc/ntp/leap-seconds
+ ntp_db_leapfile=/var/db/ntpd.leap-seconds.list
+ ntp_leapfile_sources=https://www.ietf.org/timezones/data/leap-seconds.list
+ ntp_leapfile_fetch_opts=-mq
+ ntp_leapfile_expiry_days=30
+ ntp_leapfile_fetch_verbose=NO
+ nis_client_enable=NO
+ nis_client_flags=''
+ nis_ypset_enable=NO
+ nis_ypset_flags=''
+ nis_server_enable=NO
+ nis_server_flags=''
+ nis_ypxfrd_enable=NO
+ nis_ypxfrd_flags=''
+ nis_yppasswdd_enable=NO
+ nis_yppasswdd_flags=''
+ bsnmpd_enable=NO
+ bsnmpd_flags=''
+ defaultrouter=NO
+ static_arp_pairs=''
+ static_ndp_pairs=''
+ static_routes=''
+ natm_static_routes=''
+ gateway_enable=NO
+ routed_enable=NO
+ routed_program=/sbin/routed
+ routed_flags=-q
+ mrouted_enable=NO
+ mrouted_program=/usr/local/sbin/mrouted
+ mrouted_flags=''
+ ipxgateway_enable=NO
+ ipxrouted_enable=NO
+ ipxrouted_flags=''
+ arpproxy_all=NO
+ forward_sourceroute=NO
+ accept_sourceroute=NO
+ atm_enable=NO
+ atm_pvcs=''
+ atm_arps=''
+ hcsecd_enable=NO
+ hcsecd_config=/etc/bluetooth/hcsecd.conf
+ sdpd_enable=NO
+ sdpd_control=/var/run/sdp
+ sdpd_groupname=nobody
+ sdpd_username=nobody
+ bthidd_enable=NO
+ bthidd_config=/etc/bluetooth/bthidd.conf
+ bthidd_hids=/var/db/bthidd.hids
+ rfcomm_pppd_server_enable=NO
+ rfcomm_pppd_server_profile='one two'
+ rfcomm_pppd_server_one_channel=1
+ rfcomm_pppd_server_two_channel=3
+ ubthidhci_enable=NO
+ netwait_enable=NO
+ netwait_timeout=60
+ netwait_if_timeout=30
+ icmp_bmcastecho=NO
+ ipv6_network_interfaces=auto
+ ipv6_activate_all_interfaces=NO
+ ipv6_defaultrouter=NO
+ ipv6_static_routes=''
+ ipv6_gateway_enable=NO
+ ipv6_cpe_wanif=NO
+ ipv6_privacy=NO
+ route6d_enable=NO
+ route6d_program=/usr/sbin/route6d
+ route6d_flags=''
+ ipv6_default_interface=NO
+ rtsol_flags=''
+ rtsold_enable=NO
+ rtsold_flags=-a
+ rtadvd_enable=NO
+ rtadvd_interfaces=''
+ mroute6d_enable=NO
+ mroute6d_program=/usr/local/sbin/pim6dd
+ mroute6d_flags=''
+ stf_interface_ipv4addr=''
+ stf_interface_ipv4plen=0
+ stf_interface_ipv6_ifid=0:0:0:1
+ stf_interface_ipv6_slaid=0000
+ ipv6_faith_prefix=NO
+ ipv6_ipv4mapping=NO
+ ipv6_ipfilter_rules=/etc/ipf6.rules
+ ip6addrctl_enable=YES
+ ip6addrctl_verbose=NO
+ ip6addrctl_policy=AUTO
+ keyboard=''
+ keymap=NO
+ keyrate=NO
+ keybell=NO
+ keychange=NO
+ cursor=NO
+ scrnmap=NO
+ font8x16=NO
+ font8x14=NO
+ font8x8=NO
+ blanktime=300
+ saver=NO
+ moused_nondefault_enable=YES
+ moused_enable=NO
+ moused_type=auto
+ moused_port=/dev/psm0
+ moused_flags=''
+ mousechar_start=NO
+ allscreens_flags=''
+ allscreens_kbdflags=''
+ mta_start_script=/etc/rc.sendmail
+ sendmail_enable=NO
+ sendmail_pidfile=/var/run/sendmail.pid
+ sendmail_procname=/usr/sbin/sendmail
+ sendmail_flags='-L sm-mta -bd -q30m'
+ sendmail_cert_create=YES
+ sendmail_submit_enable=YES
+ sendmail_submit_flags='-L sm-mta -bd -q30m -ODaemonPortOptions=Addr=localhost'
+ sendmail_outbound_enable=YES
+ sendmail_outbound_flags='-L sm-queue -q30m'
+ sendmail_msp_queue_enable=YES
+ sendmail_msp_queue_flags='-L sm-msp-queue -Ac -q30m'
+ sendmail_rebuild_aliases=NO
+ auditd_enable=NO
+ auditd_program=/usr/sbin/auditd
+ auditd_flags=''
+ auditdistd_enable=NO
+ auditdistd_program=/usr/sbin/auditdistd
+ auditdistd_flags=''
+ cron_enable=YES
+ cron_program=/usr/sbin/cron
+ cron_dst=YES
+ cron_flags=''
+ lpd_enable=NO
+ lpd_program=/usr/sbin/lpd
+ lpd_flags=''
+ nscd_enable=NO
+ chkprintcap_enable=NO
+ chkprintcap_flags=-d
+ dumpdev=NO
+ dumpdir=/var/crash
+ savecore_flags='-m 10'
+ crashinfo_enable=YES
+ crashinfo_program=/usr/sbin/crashinfo
+ quota_enable=NO
+ check_quotas=YES
+ quotaon_flags=-a
+ quotaoff_flags=-a
+ quotacheck_flags=-a
+ accounting_enable=NO
+ ibcs2_enable=NO
+ ibcs2_loaders=coff
+ firstboot_sentinel=/firstboot
+ sysvipc_enable=NO
+ linux_enable=NO
+ svr4_enable=NO
+ clear_tmp_enable=NO
+ clear_tmp_X=YES
+ ldconfig_insecure=NO
+ ldconfig_paths='/usr/lib/compat /usr/local/lib /usr/local/lib/compat/pkg'
+ ldconfig32_paths='/usr/lib32 /usr/lib32/compat'
+ ldconfig_paths_aout='/usr/lib/compat/aout /usr/local/lib/aout'
+ ldconfig_local_dirs=/usr/local/libdata/ldconfig
+ ldconfig_local32_dirs=/usr/local/libdata/ldconfig32
+ kern_securelevel_enable=NO
+ kern_securelevel=-1
+ update_motd=YES
+ entropy_file=/entropy
+ entropy_dir=/var/db/entropy
+ entropy_save_sz=2048
+ entropy_save_num=8
+ harvest_interrupt=YES
+ harvest_ethernet=YES
+ harvest_p_to_p=YES
+ harvest_swi=YES
+ dmesg_enable=YES
+ watchdogd_enable=NO
+ watchdogd_flags=''
+ devfs_rulesets='/etc/defaults/devfs.rules /etc/devfs.rules'
+ devfs_system_ruleset=''
+ devfs_set_rulesets=''
+ devfs_load_rulesets=YES
+ performance_cx_lowest=HIGH
+ performance_cpu_freq=NONE
+ economy_cx_lowest=HIGH
+ economy_cpu_freq=NONE
+ virecover_enable=YES
+ ugidfw_enable=NO
+ bsdextended_script=/etc/rc.bsdextended
+ newsyslog_enable=YES
+ newsyslog_flags=-CN
+ mixer_enable=YES
+ opensm_enable=NO
+ rctl_enable=NO
+ rctl_rules=/etc/rctl.conf
+ jail_enable=NO
+ jail_parallel_start=NO
+ jail_list=''
+ [ -z '' ]
+ source_rc_confs_defined=yes
+ source_rc_confs
+ local i sourced_files
+ sourced_files=:/etc/rc.conf:
+ [ -r /etc/rc.conf ]
+ . /etc/rc.conf
+ portmap_enable=NO
+ sshd_enable=NO
+ sendmail_submit_enable=NO
+ sendmail_outbound_enable=NO
+ sendmail_msp_queue_enable=NO
+ hostname=plexmediaserver_1
+ devfs_enable=YES
+ devfs_system_ruleset=devfsrules_common
+ inet6_enable=YES
+ plexmediaserver_support_path=/var/db/plexdata
+ plexmediaserver_enable=YES
+ sourced_files=:/etc/rc.conf::/etc/rc.conf.local:
+ [ -r /etc/rc.conf.local ]
+ _rc_conf_loaded=true
+ [ -n plexmediaserver ]
+ _d=/etc
+ [ -f /etc/rc.conf.d/plexmediaserver ]
+ [ -d /etc/rc.conf.d/plexmediaserver ]
+ _d=/usr/local/etc
+ [ -f /usr/local/etc/rc.conf.d/plexmediaserver ]
+ [ -d /usr/local/etc/rc.conf.d/plexmediaserver ]
+ eval '_defval=$plexmediaserver_enable_defval'
+ _defval=''
+ [ -n '' ]
+ : YES
+ : /var/db/plexdata
+ : plex
+ : plex
+ : 6
+ command=/usr/sbin/daemon
+ procname=/usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex_Media_Server
+ command_args='-f /usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex_Media_Server'
+ pidfile=/var/run/plex/plex.pid
+ start_precmd=plex_precmd
+ stop_precmd=plex_stop_precmd
+ stop_postcmd=plex_stop_postcmd
+ run_rc_command ''
+ _return=0
+ rc_arg=''
+ [ -z plexmediaserver ]
+ shift 1
+ rc_extra_args=''
+ _rc_prefix=''
+ eval '_override_command=$plexmediaserver_program'
+ _override_command=''
+ _keywords='start stop restart rcvar enabled '
+ rc_pid=''
+ _pidcmd=''
+ _procname=/usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex_Media_Server
+ [ -n /usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex_Media_Server ]
+ [ -n /var/run/plex/plex.pid ]
+ _pidcmd='rc_pid=$(check_pidfile /var/run/plex/plex.pid /usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex_Media_Server )'
+ [ -n 'rc_pid=$(check_pidfile /var/run/plex/plex.pid /usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex_Media_Server )' ]
+ _keywords='start stop restart rcvar enabled status poll'
+ [ -z '' ]
+ rc_usage start stop restart rcvar enabled status poll
+ echo -n 'Usage: plexmediaserver [fast|force|one|quiet]('
Usage: plexmediaserver [fast|force|one|quiet](+ _sep=''
+ echo -n start
start+ _sep='|'
+ echo -n '|stop'
|stop+ _sep='|'
+ echo -n '|restart'
|restart+ _sep='|'
+ echo -n '|rcvar'
|rcvar+ _sep='|'
+ echo -n '|enabled'
|enabled+ _sep='|'
+ echo -n '|status'
|status+ _sep='|'
+ echo -n '|poll'
|poll+ _sep='|'
+ echo ')'
+ exit 1
Thanks @mikec_pt, I have fixed this issue on my FreeNas with your advise.
Here’s how I fix it:
jexec {PLEX_SERVER_JAIL_NUMBER}
export LD_LIBRARY_PATH="%%PREFIX%%/lib/compat:${SCRIPTPATH}" and replace with export LD_LIBRARY_PATH="${SCRIPTPATH}/lib"
Yeah that’s fine, but I didn’t post the full command, sorry it should be: sh -x /usr/local/etc/rc.d/plexmediaserver start
Tried what you have suggested. Worked for me. Thank you very much.
Edit:
Force update with PMS script just for testing is still not working…
Here is the full command output:
+ . /etc/rc.subr
+ : 12738
+ export RC_PID
+ [ -z '' ]
+ ID=/usr/bin/id
+ PS='/bin/ps -ww'
+ /bin/ps -ww -p 12738 -o jid=
+ JID=0
+ _rc_subr_loaded=:
+ false
+ rc_info=NO
+ rc_startmsgs=YES
+ apm_enable=NO
+ apmd_enable=NO
+ apmd_flags=''
+ ddb_enable=NO
+ devd_enable=YES
+ devd_flags=''
+ kldxref_enable=NO
+ powerd_enable=NO
+ powerd_flags=''
+ tmpmfs=AUTO
+ tmpsize=20m
+ tmpmfs_flags=-S
+ varmfs=AUTO
+ varsize=32m
+ varmfs_flags=-S
+ populate_var=AUTO
+ zfs_enable=NO
+ gbde_devices=NO
+ gbde_lockdir=/etc
+ geli_devices=''
+ geli_tries=''
+ root_rw_mount=YES
+ fsck_y_enable=NO
+ fsck_y_flags=''
+ hostname=''
+ hostid_enable=YES
+ nisdomainname=NO
+ dhclient_flags=''
+ firewall_quiet=NO
+ firewall_logif=NO
+ firewall_flags=''
+ ike_enable=NO
+ ike_flags=''
+ ipsec_enable=NO
+ natd_enable=NO
+ natd_interface=''
+ natd_flags=''
+ ipfilter_flags=''
+ ipnat_enable=NO
+ ipnat_flags=''
+ ipmon_enable=NO
+ ipmon_flags=-Ds
+ ipfs_enable=NO
+ ipfs_flags=''
+ pf_enable=NO
+ pf_flags=''
+ pflog_enable=NO
+ pflog_flags=''
+ ftpproxy_flags=''
+ pfsync_enable=NO
+ pfsync_syncdev=''
+ log_in_vain=0
+ tcp_keepalive=YES
+ fec_interfaces=''
+ ppp_enable=NO
+ ppp_mode=auto
+ ppp_nat=YES
+ ppp_user=root
+ hostapd_enable=NO
+ syslogd_flags=-s
+ inetd_enable=NO
+ iscsid_enable=NO
+ hastd_enable=NO
+ hastd_flags=''
+ ctld_enable=NO
+ kdc_enable=NO
+ kdc_flags=''
+ kadmind_enable=NO
+ kfd_enable=NO
+ kfd_flags=''
+ gssd_enable=NO
+ gssd_flags=''
+ rwhod_enable=NO
+ rwhod_flags=''
+ rarpd_enable=NO
+ rarpd_flags=-a
+ pppoed_enable=NO
+ sshd_enable=NO
+ sshd_flags=''
+ ftpd_enable=NO
+ ftpd_flags=''
+ amd_enable=NO
+ autofs_enable=NO
+ mountd_enable=NO
+ mountd_flags=-r
+ nfs_bufpackets=''
+ rpcbind_enable=NO
+ rpcbind_flags=''
+ keyserv_enable=NO
+ keyserv_flags=''
+ nfscbd_enable=NO
+ nfscbd_flags=''
+ nfsuserd_flags=''
+ timed_enable=NO
+ timed_flags=''
+ ntpdate_enable=NO
+ ntpdate_flags=-b
+ ntpdate_hosts=''
+ ntpd_enable=NO
+ bsnmpd_enable=NO
+ bsnmpd_flags=''
+ defaultrouter=NO
+ static_routes=''
+ gateway_enable=NO
+ routed_enable=NO
+ routed_flags=-q
+ mrouted_enable=NO
+ mrouted_flags=''
+ arpproxy_all=NO
+ atm_enable=NO
+ atm_pvcs=''
+ atm_arps=''
+ hcsecd_enable=NO
+ sdpd_enable=NO
+ bthidd_enable=NO
+ netwait_enable=NO
+ ipv6_cpe_wanif=NO
+ ipv6_privacy=NO
+ route6d_enable=NO
+ route6d_flags=''
+ rtsol_flags=''
+ rtsold_enable=NO
+ rtsold_flags=-a
+ rtadvd_enable=NO
+ mroute6d_flags=''
+ keyboard=''
+ keymap=NO
+ keyrate=NO
+ keybell=NO
+ keychange=NO
+ cursor=NO
+ scrnmap=NO
+ font8x16=NO
+ font8x14=NO
+ font8x8=NO
+ blanktime=300
+ saver=NO
+ moused_enable=NO
+ moused_type=auto
+ moused_flags=''
+ auditd_enable=NO
+ auditd_flags=''
+ cron_enable=YES
+ cron_dst=YES
+ cron_flags=''
+ lpd_enable=NO
+ lpd_flags=''
+ nscd_enable=NO
+ dumpdev=NO
+ quota_enable=NO
+ check_quotas=YES
+ quotaon_flags=-a
+ quotaoff_flags=-a
+ ibcs2_enable=NO
+ sysvipc_enable=NO
+ linux_enable=NO
+ svr4_enable=NO
+ clear_tmp_X=YES
+ update_motd=YES
+ harvest_swi=YES
+ dmesg_enable=YES
+ ugidfw_enable=NO
+ mixer_enable=YES
+ opensm_enable=NO
+ rctl_enable=NO
+ jail_enable=NO
+ jail_list=''
+ [ -z '' ]
+ source_rc_confs
+ . /etc/rc.conf
+ portmap_enable=NO
+ sshd_enable=NO
+ devfs_enable=YES
+ inet6_enable=YES
+ _d=/etc
+ _d=/usr/local/etc
+ _defval=''
+ [ -n '' ]
+ : YES
+ : plex
+ : plex
+ : 6
+ run_rc_command start
+ _return=0
+ rc_arg=start
+ shift 1
+ rc_extra_args=''
+ _rc_prefix=''
+ rc_pid=''
+ _pidcmd=''
+ [ -z start ]
+ [ start = enabled ]
+ [ -n '' ]
+ eval 'rc_flags=$plexmediaserver_flags'
+ rc_flags=''
+ eval '_chdir=$plexmediaserver_chdir' '_chroot=$plexmediaserver_chroot' '_nice=$plexmediaserver_nice' '_user=$plexmediaserver_user' '_group=$plexmediaserver_group' '_groups=$plexmediaserver_groups' '_fib=$plexmediaserver_fib' '_env=$plexmediaserver_env' '_prepend=$plexmediaserver_prepend'
+ _chdir='' _chroot='' _nice='' _user=plex _group=plex _groups='' _fib='' _env='' _prepend=''
+ [ -n plex ]
+ eval if [ -x /usr/bin/id '];' then /usr/bin/id '-un;' fi
+ [ -x /usr/bin/id ]
+ /usr/bin/id -un
+ [ plex = root ]
+ [ -z '' ]
+ eval 'rc_pid=$(check_pidfile' /var/run/plex/plex.pid /usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex_Media_Server ')'
+ check_pidfile /var/run/plex/plex.pid /usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex_Media_Server
+ _pidfile=/var/run/plex/plex.pid
+ _interpreter=''
+ [ -z /var/run/plex/plex.pid -o -z /usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex_Media_Server ]
+ [ ! -f /var/run/plex/plex.pid ]
+ debug 'pid file (/var/run/plex/plex.pid): not readable.'
+ return
+ rc_pid=''
+ [ start != start ]
+ [ -n plexmediaserver_enable -a start != rcvar -a start != stop ]
+ checkyesno plexmediaserver_enable
+ eval '_value=$plexmediaserver_enable'
+ _value=YES
+ debug 'checkyesno: plexmediaserver_enable is set to YES.'
+ return 0
+ [ start = start -a -z '' -a -n '' ]
+ eval '_cmd=$start_cmd' '_precmd=$start_precmd' '_postcmd=$start_postcmd'
+ _cmd='' _precmd=plex_precmd _postcmd=''
+ [ -n '' ]
+ [ ! -x /usr/sbin/daemon ]
+ _run_rc_precmd
+ check_required_before start
+ local _f
+ return 0
+ [ -n plex_precmd ]
+ debug 'run_rc_command: start_precmd: plex_precmd '
+ eval 'plex_precmd '
+ plex_precmd
+ [ -f /etc/version ]
+ export PLEX_MEDIA_SERVER_INFO_VENDOR=FreeBSD
+ export PLEX_MEDIA_SERVER_INFO_DEVICE=PC
+ uname -m
+ export PLEX_MEDIA_SERVER_INFO_MODEL=amd64
+ uname -r
+ export PLEX_MEDIA_SERVER_INFO_PLATFORM_VERSION=11.1-STABLE
+ export TMPDIR=/tmp
+ export SUPPORT_PATH=/var/db/plexdata
+ export 'HOME=/var/db/plexdata/Plex Media Server'
+ export PYTHONHOME=/usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Resources/Python
+ export SCRIPTPATH=/usr/pbi/plexmediaserver-amd64/share/plexmediaserver
+ export LD_LIBRARY_PATH=/usr/pbi/plexmediaserver-amd64/share/plexmediaserver/lib
+ export PLEX_MEDIA_SERVER_HOME=/usr/pbi/plexmediaserver-amd64/share/plexmediaserver
+ export PLEX_MEDIA_SERVER_MAX_PLUGIN_PROCS=6
+ export PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR=/var/db/plexdata
+ export PLEX_MEDIA_SERVER_PIDFILE=/var/run/plex/plex.pid
+ export 'PLEX_MEDIA_SERVER_LOG_DIR=/var/db/plexdata/Plex Media Server/Logs'
+ export PATH=/usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Resources/Python/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/games:/usr/local/sbin:/usr/local/bin:/root/bin
+ export LC_ALL=en_US.UTF-8
+ export LANG=en_US.UTF-8
+ ulimit -s 3000
+ [ ! -d /var/run/plex ]
+ [ ! -d '/var/db/plexdata/Plex Media Server' ]
+ _return=0
+ [ 0 -ne 0 ]
+ check_required_after start
+ local _f _args
+ return 0
+ return 0
+ check_startmsgs
+ [ -n '' ]
+ return 0
+ echo 'Starting plexmediaserver.'
+ [ -n '' ]
+ _doit='/usr/sbin/daemon -f /usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex_Media_Server'
+ [ -n plex ]
+ _doit='su -m plex -c '\''sh -c "/usr/sbin/daemon -f /usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex_Media_Server"'\'
+ [ -n '' ]
+ [ -n '' ]
+ _run_rc_doit 'su -m plex -c '\''sh -c "/usr/sbin/daemon -f /usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex_Media_Server"'\'
+ debug 'run_rc_command: doit: su -m plex -c '\''sh -c "/usr/sbin/daemon -f /usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex_Media_Server"'\'
+ eval 'su -m plex -c '\''sh -c "/usr/sbin/daemon -f /usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex_Media_Server"'\'
+ su -m plex -c 'sh -c "/usr/sbin/daemon -f /usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex_Media_Server"'
+ _return=0
+ [ 0 -ne 0 ]
+ return 0
+ _run_rc_postcmd
+ [ -n '' ]
+ return 0
+ return 0
This worked for me on version Version 1.15.2.793
Changed:
export LD_LIBRARY_PATH="${SCRIPTPATH}"
to
How do i actually update freenas 11.2 plugin plex -plexpass ? I Can’t do it with the plugin in freenas and I cant do it the ordinary way I did it with Jail…
So What commandline should I use to update to the latest plexversion?
Please help!
Well to update the plugin you should just use the same method as you normally do to update plugins in FreeNAS, if however you want to “Ditch” the plugin and use the terminal to update in the jail it self, you can just use the standard freebsd way via pkgng (or even ports).
So in the comandline (in the jails shell) you can use:
pkg upgrade to upgrade all installed packages
pkg install plexmediaserver OR pkg install plexmediaserver-plexpass to install if not installed
It just says that the newest version is installed. Which it’s definitely not. Any idea what’s up?
You mean the plugin? That’s normal, the latest version of the plugin is indeed installed but doesn’t necessarily reflect the latest build from plex.tv, even form pkgng you also need to wait at least a couple of days but from what users post here it seems the plugin does take much longer to update, this is something that would need to be raised in the freenas forums, as they have the control of the plugin.
Thanks all, this fixed my problem.
FreeNAS jail with PMS_Updater.
Hi, All
I have Freenas 11.2 U2.1 and have same Issue after update PMS 1.14.5488 to 1.15 with PMS_Update.sh.
I already try to change in script export LD_LIBRARY_PATH="${SCRIPTPATH}/lib" but it still no longer to solve the problem. I use Plex with plexpass.
Did somebody have an idea ?
Thanks.
For the moment i downgrade to PMS 1.14.5488.
Same here, Freenas 11.2 U2.1 PMS_update.sh.
Curious how you downgraded though, reinstall?
Did you find an answer to this problem? I’m running into the exact same error even with the fix in this thread applied.
Not yet. I haven’t had time to troubleshoot since that night. Hoping I can try again this weekend.
This worked for me, and I managed to learn to use vi for editing (which is a first for me) thanks!
THE PMS_Updater.sh make a backup directory to plexmexxxx.bak. You remove the directory and rename the .bak.
