@colinoice @danielicetv Welcome to the Plex forums!!
Great news about the new IceTV offering and such a great price
@danjames92 said:
@Andrroid said:
So how does this relate to Plex?Provides a arguably better tv guide for DVR than Plexās current iteration for Australiansā¦
@danjames92 itās not arguably better, itās about 2-3 orders of magnitude better. Specifically itās pristine, hand-curated Australian EPG feed that will allow you to make the most of your Plex DVR. No missing channels, no missing shows, new/repeat indicators, episode numbering, etc
@john2069 said:
I said arguably that I have no prior experience of using a AU TV guide as a British person living in the UK and saw others recommend it hence the āarguablyā.
@BastardSheep said:
Ok, so Iām trying to set this up. Deleted the I enter the URL for the XML and click on next, it goes to āLoading Channel Mappingsā then āUnable to load channel mappingsā.
Did you ever fix/overcome this issue?
I have the same error.
Using a HDHomerun Connect in Perth, WA.
@IX9 said:
@BastardSheep said:
Ok, so Iām trying to set this up. Deleted the I enter the URL for the XML and click on next, it goes to āLoading Channel Mappingsā then āUnable to load channel mappingsā.Did you ever fix/overcome this issue?
Nope. Last I heard from IceTV is that my logs looked like it was all working fine, so they had sent the logs to Plex for their feedback. Havenāt heard anything since.
Itās not enough of an issue for me to chase it up - Gracenote is FAR from perfect and FAR from what I know IceTV provides, but itās good enough for my needs.
Get KODI and install add-on Works great! Forget plex
Iāve posted same problem 6 months ago still no fix.
We are working on it right now but itās obscure only effecting a small number of users
Plex are now zeroing in on the bug
@colinoice Iāve just commenced a trial on the XMLTV, now that LiveTV has been implemented we will make more use of this service than just the DVR of old.
Whilst the IceTV EPG is certainly a significant improvement over the baked in Plex Gracenote EPG guide Iāve noticed a couple of issues which would be great to have fixed.
@kanine69 Issue 2)
is something that Plex will address on their side. Itās in the pipeline.
I have been using IceTV since they made the Plex guide feed and it has been improving and they are responsive to fixing any errors and more and more shows have accurate season and episode coding. I had to reinstall the tuners a month ago and tried Gracenote and even when you ignore the fact that they donāt support Rural Australia it is still not that good. If you do a lot of recording IceTV is very good.
Incorrect Post
@colinoice I took the liberty of running a post process script over the XMLTV file prior to Plex processing it, it resolves the content quality issue, and generates a basic thumb for any that are missing. Here is the result, which is a massive improvement in UI for little effortā¦
Images are created automagically through ImageMagickĀ®
Ok, as an update we have fixed the HD flags in the feed.
Not sure about the viability of the placeholder images on the server end, but something we can look into.
Thatās a big help thanks! Placeholder generation was easy with the Open Source tool I used, happy to share the commands if it helps.
@kanine69 said:
Thatās a big help thanks! Placeholder generation was easy with the Open Source tool I used happy to share the commands if it helps.
Please do.
@danielicetv said:
Please do.
Here you go, itās a simple Windows Command File. I changed my āBlankā to remove the Plex Logo as thatās not appropriate hereā¦
Imagick is multiplatform so probably has an environment for whatever your IDE is.
@BastardSheep said:
Using a HDHomerun Connect in Perth, WA.Nope. Last I heard from IceTV is that my logs looked like it was all working fine, so they had sent the logs to Plex for their feedback. Havenāt heard anything since.
any update on this fix? same issue in VIC using a qnap plex server Version 1.7.2.3878.
Thereās been a lot of progress and testing in the last fortnight, but still no solution. I have to praise the work being put in by all involved at both IceTV and Plex, but the problem is being very tricky to track down.
