I have a playlist with 900+ episodes that i just put on random as background noise. Every now and then i get an episode plex cannot play, is there a way to figure out what episode that is? Found some errors in Console, but they do not mention what video it was trying to play.
Is there no way of doing this?
If the player you are using has a view of the current play queue, you can take a look at that.
If not, note down the current time.
Then take a look into your server logs and scroll down to the time stamp that you noted down.
(For this to work, you need to activate server debug logging in advance. Do NOT activate “verbose” logging.)
