What are the criteria for ignore files, I thought samples and trailers would be ignored, I started getting "trailer.mov" files in the movie folder and Plex is now adding them as a 2min movie...
Hmmm.
Hmmm.
I know if you use the word "Sample" in the filename, plex will ignore it. However I do not believe there is a keyword for trailers to be ignored.
files with "Trailer" in name and over 300mb will be scanned in. under 300mb gets ignored.
I believe it will ignore any movie-trailer.??? file where movie matches between the name of the content file. In other words, some_movie_name.mp4 would be cataloged but some_movie_name-trailer.mp4 would not. Sample files should be removed altogether before cataloging.
Roger that, hadn't had issues with sample files I knew they were filtered, thought trailer would be the same but the trailer thing is new for me, my renamer wasn't working with "movie-trailer.mov", it was just literally making the file "movie-trailer.mov" and not replacing the placeholder *movie*.
I will tweak and see. My trailers must be too high of quality (300mb) file I checked was less than 100mb, but also only 2min.. Perhaps if duration was a criteria to ignore for the movie scanner.
Thanks.
mmm ok interesting. will need to look into that. The main reason they put hat limit on there was they figured a full length movie would be over 300mb and there are a bunch of movies with trailer in the name.
so would "Batman-trailer.mov" be exactly how you would have it named? (i want to test it when i get a chance)
I blew out three "trailer.mov" files all under 100MB and 2min long according to PlexWeb. I can try renaming one with *movie*-trailer.mov and see if it disappears.
