Wow, I would love what you say to be “true” but for me that seems like an ‘alternate fact’ -
It’s been about a year since the Plex Feature to select the best version of a video for streaming is ‘false’.
In recent memory, I can’t recall a time when Plex didn’t choose the highest quality (4K for example) and transcode it down to as low resolution well below other resolution versions located in the same folder.
A few folders contain 2160p, 1080p and 720p resolutions all created from the same source and yet, Plex has selected the 2160p version of the movie and transcoded it down to 720p or even 480p for streaming! - man, that can really kill my 8-core 16-thread APU (Ryzen 7 5700G + Make it Hurt) and leave barely enough CPU % for other tasks, let alone a second Transcode.
But I do like the Drop down menu – at least for manually selecting which Video Source file to choose for streaming!
What happens if transcoding is turned off?
The one problem, for me, is that the main Move Poster shown in the Collection Library doesn’t show these “alternate cuts/versions” in the Libray and only reveal the video options only after you have selected the Title and gone to the Description Page.
One other addition I would make to this idea would be to carry over the ‘version icon overlays’ to the main Collection Poster using the same translucent version icons overlayed on the Poster in a horizontal fashion along the right-hand side of the Poster Artwork.
Great Work, thanks for your creativity.
If you prune files you’ve watched the Multiple Cuts is completely irrelevant to you. Multiple Cuts of a Movie are very much a long-term thing. If you delete it after you’ve watched it then you are only ever going to have a single version.
But for those of us who have our DVD collection on Plex because those are the movies that we buy & not rent because they are going to be watched multiple times, having an option of watching the Theatrical version or Extended version of The Ring Lord, or the British version or American version of The Hairy Potter, or the Original or Remastered version of Near Encounters of the 4th Kind, or if people want to choose if they watch the Solo Hun shoot 1st or not when watching The War of the Stars, or even for home movies if you had Dad’s recording of Easter 2015 & also had Aunt Susan’s recording of the same event you could have one entry for them but with 2 different play options. So for those who would use this feature it’s anything BUT fleeting information.
& showing the “filename in the drop down menu” is just a crude & ugly way of doing it. If that’s what we get fine, we’ll use it, but it’s far from the best way. & I made this mockup because the .plexmatch is a new thing that I feel us highly under utilized but has the potential to be used for a lot of things with the structure of the file.
As of now you use “hints” as they call them to help Plex match things that are not named well.
I had an issue awhile back with a show that was titled “3x3 Eyes” & after an update Plex decided that the files, even though they were properly named according to the Plex Naming Conventions, “3x3 Eyes S01E01.mp4”, “3x3 Eyes S01E02.mp4”, “3x3 Eyes S01E03.mp4”, “3x3 Eyes S01E04.mp4”, & “3x3 Eyes S02E01.mp4”, “3x3 Eyes S02E02.mp4”, “3x3 Eyes S02E03.mp4” were all different versions of Season 3 Episode 3. So for things like that I get it.
But you can only use the .plexmatch file, as of now, to say “Match to this TVdb ID or IMdb ID or TMdb ID”, or say “Match to this title & release year”, or say “for this file match it to this episode of the show”.
So there’s lots of room to grow. I have another feature suggestion for giving us the abilities to match an episode to a different episode than what it’s named as. There are lots of cases where this is useful, again for those of us who keep stuff on our servers not the single-use crowd.
Like shows that have different episode numberings on TVdb than on the DVDs some are getting them from, & TVdb has a DVD order, but sometimes those are not what we, as users, have or want. Some shows have alternate orders but Plex only lets you use Airing, DVD, or Absolute. That doesn’t work for everything.
The basics of the .plexmatch are very simple.
- Identify what is being hinted
- give a hint
- tell where that hint goes
All separated with a :
so cut: would be saying that this hint is telling Plex that this line is going to be telling it how to sort that then WHATEVER NAME: is telling it that that is what “Cut” this line is dealing with then the last, for this case would have to be the file name. For TV shows there are other options, like using a .plexmatch file to name a folder as a season & everything in that folder will override any season numbering on the files.
This .plexmatch tool only came out in March, so it’s brand new, meaning they are most likely still working to improve it. This feature suggestion has been around for 10 years & has over 1500 votes, that tells me that the problem is most likely a “How To” so, even though I think better ones have been suggested already, there must be some reason those haven’t made the cut, since this is new, it’s development is still fresh & probably still being worked on, I’d rather an inelegant solution than no solution at all.
The problem with that is that if transcoding is off then you CAN’T do anything except play the original quality. But from my experience even then it won’t play the lower quality version.
I had a movie at 1080p with a bitrate of 6 or 8 Mbps, not excessively high by any means, but I also had a version at 720p that was just over 1Mbps & a 480p version that was about 700kbps. I had bad upload speeds that capped out at 2Mbps on a good day where I was at so I had remote streaming limited to 1.5Mbps which Plex has as 1.5Mbps (480p).
The 720p file was AVC (H.264) High V3.0 with AAC Stereo audio, so everything can play it, the 480 was similar with a lower profile.
But when streaming from away it would play the 1080p file transcoded down to 480 using more bandwidth than if it had played the 720 or the 480 file that was already there.
When I disabled Video Stream transcoding it just told me that I couldn’t watch it. But even if that worked it would mean that the other things that I might want it to transcoded when needed wouldn’t.
It wouldn’t let you select the 480p version?
It used to work, I have several 720p versions for remote streaming. I usually select manually, but it seemed to work.
And I have a few libraries with version from the Optimize feature because the originals don’t play well on some devices.
Not discounting the cuts option as I have lost of alternate cuts and would like a better solution.
If I go to Play Version & select the 480 version I believe it would play, but the 720 version wouldn’t, even though it was below the bitrate limit. But even that doesn’t work for things like a playlist. I tried a lot of ways to do it & none worked.
I have a bunch of music videos that I would play in the car for the kids while we are driving, they are each only a couple minutes long, but they play in a playlist. I don’t need or want a high res version using my car’s limited bandwidth so I tried having multiple versions, I even tried having Plex do it’s Optimize & make lower resolution & larger file size versions than what I already had, but it always transcodes the highest quality down. I ended up making a separate season with the low quality versions so I can make a playlist from those seasons or shuffle the season. That was the only way I found to make it work
As someone who has many versions of films ie Directors Cuts etc. This would be so helpful!
Definitely sounds like a bug. It certainly should have selected the Optimized versions.
I thought it was working a few years ago, but I haven’t tested it since 2019 (haven’t been in the situation that warranted it since then).
But even then I didn’t use the playlist function. It was just to easily play some old MPEG2 videos.
That was my thought at 1st but I found from some searching when I had a lot of extra time (this was early days of “The Great Quarantine”) that it was common, lots of others experienced the same & Plex didn’t care to fix it or consider it a problem
Seems to be a common theme with the Plex devs.
It seems like this has been implemented… kind of?
But it’s implemented in a really haphazard way. Both the Workprint and the Final Cut have to have their posters displayed in the library, it doesn’t appear to allow me to hide one so it’s only accessible via the main movie’s info page.
Also… was this feature released unannounced? I didn’t see it mentioned anywhere official, and nobody has mentioned it here before me.
EDIT: I tried adding the Workprint to a collection named “Alternate Cuts”, but you can’t hide a collection and hide the items in the collection at the same time. So there doesn’t seem to be a workaround.
What version are you using to see that?
This work is not completed and should not be considered implementeed, but should be out “soon’ish”. I’m not going to get into details yet about how they work as things are still changing. and it may be removed in an update until it is finished.
Use https://app.plex.tv to be able to see this at this time.
-Shark2k
Nice to know there is movement with this feature request.
Nice to know this is getting worked on, but please don’t implement this at the bottom of the pages for the media apps, I would personally prefer something like the mockup I posted previously (which I’ll add again for reference).
So far, this is only a first version that has made it into the web version. Therefore, my hope is high that in the final version the appropriate adjustments will be made. But it would be really nice if, in the web version as well as in the respective apps, it is displayed prominently that there are multiple versions of a movie. I am really looking forward to see how this will be implemented in the end.
It’s good that you pulled out the mockup again.
Did Workprint and Final Cut come from your naming?
How do you have the 2 versions named/stored in the library?
Does it work with more than 2?
Alternatively, create a row of posters (almost like the extra content row), and position it right below the play button and above the cast portraits. Seeing the actors front and center is less important than knowing there are multiple cuts to choose from.
I’m actually going to have to disagree, I like to see the cast font and centre haha. I just hope theres an option to keep only “one” version of the movie in my “library” with the option to switch between them when you’re viewing it (but I suppose thats just personal preference, I don’t want/need the clutter lol)
