In direct connection on local network
Hi all. I’m trying to use the Plex app on my PS4 but it says it has an indirect connection and limits the speed/quality.
Every other app on my network (ios, android) are fine and get a direct connection and the PS4 is right net to the server and all remote connections are also fine.
Do I need to set something up on the app or my router (Fritzbox)?
Hi all! I have the same problem. The connection to my server (PS4 pro and Plex Server are connected with 1Gb LAN) need a couple of minutes and then there is the message, that I don’t have a direct connection.
I also use a Fritzbox.
Is there a guy with the same problem and could tell us a solution?
Same here!
I think the PS4 version has been dropped as I get this too and have given up with it.
You should open port TCP 32469/32400, UDP 1900 and UDP 32410!
I solved the problem by allowing insecure connections to the plex server on the local network.
Sorry to re-open this, but I am seeing the same issues as the OP. I tried the joeldeluxe94 suggestion, but it does not work.
I get a direct connection using my iPhone (iOS), but the PS4 is not playing ball. I too have a Fritzbox! 7390, and I can’t seem to find a way to allow insecure connections to the plex server, which is running on a Synology Diskstation, on the local network.
Anyone with any further experience on this?
Thanks, J
@jkharmer: Allowing insecure connections is an option in the Playstation Plex App.
