Incredibly slow transcoding
I am setting up my Plex Server for the first time ever and while everything seems to work fine, all of the clients I have tried seem to have buffering issues (Fire Stick, Apple TV and Web client).
As usual, the two suspects can be network connectivity or CPU specs. I have looked into other threads and it appears that transcoding can show as slow because the network is slow too. I’d like to confirm this so I can focus solely on fixing my network issues.
The client is consuming a Direct Stream but transcoding audio EAC3 to AAC, I am also watching the show with subtitles. The logs show me that transcoding speeds hover in the 50 to 100 range but I have seen instances where it shows numbers such as 2991.
This is surprising to me because my CPU should be able to handle faster transcoding speeds, plus while monitoring the transcoding process on htop it never utilises more than 3% of a single CPU (it is also steady at 0.2% memory). So even though I am currently using the Plex Server to write this post and deluge is downloading torrented files, it should show better transcoding speeds.
The speednet tests show me an upload speed capacity of 1.5Mb (deluge is seeding at 1.5kb). A very probable cause for the problem could be my network configuration. My Server PC is connected to the local network via a repeater, so there could be a bottleneck there (the Apple TV is also located on a different band: 5GHz). The Web player is also connected to the network through the repeater but I have seen no improvements.
I do think the main issue here is my network connectivity but I’d like to confirm this before going on to rearrange my network setup (it can get quite crafty). Many thanks.
Edit: another contributing factor could be that all of my media files are stored in a 3.5" HDD interfaced with a 6Gb SATA cable.
Server Version #: 1.13.8.5395
CPU: Intel Core I5-6600K Processor (3.5 GHz, 6 M Cache)
There is no way to guess at the cause.
  1. Settings - Server - General – DEBUG logging ON, Verbose OFF
  2. Recreate the problem for 30 seconds
  3. Stop Playback
  4. Wait 30 seconds
  5. Settings - Server - Help - Download Logs
  6. Attach the ZIP file.
Here you go:
Plex Media Server Logs_2018-10-14_18-22-26.zip (2.4 MB)
Is there a way to look if Plex is being resource limited? I suspect it cannot use more than 0.2% of my memory.
Please do it again.
Per my request in step #1: 1. Settings - Server - General – DEBUG logging ON, Verbose OFF
You have Verbose ON.
The data I need has already rolled off the back end of the logs due to how verbose VERBOSE really is.
My bad, I must have not waited enough time to reproduce after disabling verbose.
Hoping this one will do:
Plex Media Server Logs_2018-10-15_00-28-29.zip (2.5 MB)
Thank you for that . It is much better.
Verbose only lets me see 2-3 minutes of elapsed time.
Debug lets me see up to about 2 hours . :slight_smile:
I am not seeing any indication of error or the CPU being slow whatsoever.
I am seeing 35 minutes of particular files being played. (2099 seconds)
Oct 15, 2018 00:26:02.002 [0x7f33077ff700] DEBUG - Play progress on 5 'Virtù e Fortuna' - got played 2099000 ms by account 1!
Oct 15, 2018 00:26:02.005 [0x7f33077ff700] DEBUG - [Now] User is faurehu (ID: 1)
Oct 15, 2018 00:26:02.005 [0x7f33077ff700] DEBUG - [Now] Device is Firefox (Firefox).
I do not understand how it can be slow.
I see where the ASS subtitles are selected.
Are you forcibly burning them in? What does the CPU loading show?
Is this a network transport problem for this bitrate?
Buffering has stopped now!
I thought it was because I switched subtitles off but then I tested them back on and everything is smooth now.
I have no idea what has fixed it but there are two events that could have impacted performance. I logged out of my session hence it might have restarted the PMS daemon (I suspect that because it is being run by its own user, the daemon runs even though there is no user logged into), and I restarted my cable modem.
Here are some logs if there’s any interest in finding an explanation:
Plex Media Server Logs_2018-10-15_12-16-07.zip (2.2 MB)
Anyway, thanks for your help.
Restarting the cable modem is the most likely root cause. Those things are notorious
