Plex Media Server log files would help a lot to determine what you have going on here. I’m going to guess the problem has to do with subtitles, though… (Based on what little information you have provided, that is.)
It looks like you are putting French subtitles into the stream? If so, then you are probably using some bitmapped type of subtitles. Some of those are much more CPU intensive than any other format. Even if the CPU would normally be considered more than adequate, they can be reduced to a crawl if the subtitles need to be transcoded into the video stream.
Sidecar SRT subs can be sent along side the audio and video stream and put onto the video by many of Plex’s client apps now. This would eliminate a LOT of transcoding. There are scripts that can be run to convert bitmapped subs to srt’s. Then the server just needs to send them long side, and you can get the benefits of subs as well as your media. And your server’s CPU isn’t going to hurt as badly as it appears to be here.
So first suggestion is to try the file without the subs, to see what happens to the CPU. then try again with the subs and again look at CPU. If there is a drastic difference, then you found the problem.
Also, when in doubt, start a playback session which recreates the issue; let it run a few seconds; stop it and start another which doesn’t have the problem; stop it and then collect the logs from Settings / Server / Help / Download Logs and attach the ZIP file here. We’ll gladly take a look at it.
I deleted the logs and restarted and see a bunch of
It looks like a problem with MythTV?
Plex Media Server.log:Jan 19, 2017 19:41:48.251 [0x7fbf5f7ff700] ERROR - [PlexRelay] kex protocol error: type 7 seq 11
Plex Media Server.log:Jan 19, 2017 19:41:50.171 [0x7fbf687ff700] ERROR - JobManager: child process killed by signal: 9 (Killed)
Plex Media Server.log:Jan 19, 2017 19:43:46.293 [0x7fbf687ff700] ERROR - JobManager: child process killed by signal: 9 (Killed)
Plex Media Server.log:Jan 19, 2017 19:43:46.522 [0x7fbf6affe700] ERROR - handle_stream_read error 32 Broken pipe
Plex Media Server.log:Jan 19, 2017 19:44:44.924 [0x7fbf6a7fd700] ERROR - Couldn’t copy file /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex Media Server.1.log to /tmp/tempLogs660a34bb-db14-461a-84b7-8cdbdd5b97b1/Plex Media Server.1.log: boost::filesystem::copy: Function not implemented: “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex Media Server.1.log”, “/tmp/tempLogs660a34bb-db14-461a-84b7-8cdbdd5b97b1/Plex Media Server.1.log”
Plex Media Server.log:Jan 19, 2017 19:44:44.924 [0x7fbf6a7fd700] ERROR - Couldn’t copy file /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex Media Server.2.log to /tmp/tempLogs660a34bb-db14-461a-84b7-8cdbdd5b97b1/Plex Media Server.2.log: boost::filesystem::copy: Function not implemented: “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex Media Server.2.log”, “/tmp/tempLogs660a34bb-db14-461a-84b7-8cdbdd5b97b1/Plex Media Server.2.log”
Plex Media Server.log:Jan 19, 2017 19:44:44.924 [0x7fbf6a7fd700] ERROR - Couldn’t copy file /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex Media Server.3.log to /tmp/tempLogs660a34bb-db14-461a-84b7-8cdbdd5b97b1/Plex Media Server.3.log: boost::filesystem::copy: Function not implemented: “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex Media Server.3.log”, “/tmp/tempLogs660a34bb-db14-461a-84b7-8cdbdd5b97b1/Plex Media Server.3.log”
Plex Media Server.log:Jan 19, 2017 19:44:44.924 [0x7fbf6a7fd700] ERROR - Couldn’t copy file /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex Media Server.4.log to /tmp/tempLogs660a34bb-db14-461a-84b7-8cdbdd5b97b1/Plex Media Server.4.log: boost::filesystem::copy: Function not implemented: “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex Media Server.4.log”, “/tmp/tempLogs660a34bb-db14-461a-84b7-8cdbdd5b97b1/Plex Media Server.4.log”
Plex Media Server.log:Jan 19, 2017 19:44:44.924 [0x7fbf6a7fd700] ERROR - Couldn’t copy file /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex Media Server.5.log to /tmp/tempLogs660a34bb-db14-461a-84b7-8cdbdd5b97b1/Plex Media Server.5.log: boost::filesystem::copy: Function not implemented: “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex Media Server.5.log”, “/tmp/tempLogs660a34bb-db14-461a-84b7-8cdbdd5b97b1/Plex Media Server.5.log”
Plex Media Server.log:Jan 19, 2017 19:44:44.924 [0x7fbf6a7fd700] ERROR - Couldn’t copy file /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex Media Scanner.log to /tmp/tempLogs660a34bb-db14-461a-84b7-8cdbdd5b97b1/Plex Media Scanner.log: boost::filesystem::copy: Function not implemented: "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex M
It looks like a MythTV issue…
Where do you want me to drop the logs ?
Did you delete all the other log files? I normally expect to see the previous rotation logs and the agent logs.
Also, for future reference, there is no need to use VERBOSE logging (Settings - Server - General) unless specifically requested. Verbose causes so much extra output that logs tend to ‘roll off’ and data needed is often lost.
In checking the CPU performance of the transcoder. The lowest speed rating it has is 22.7 (22.7 times faster than real time… aka 22.7 seconds of video per 1 second of elapsed transcoding). It’s not slowing down your CPU. It is making good use of it.
If you have other tasks, then yes, this will impact them as transcoding makes high demand on 2-3 threads (cores). Typically 2 cores will take a full 100% ‘hit’ while it fills the transcoder output buffer, which I do see happening (it goes to sleep when done until needed again as it should).
You have Myth and Plex on the machine. What is Myth doing? Is is capturing at the same time? It too does transcoding as it records (depending on settings). Two transcode sessions on an I5-class is noticeable.
Please further define what you mean by ‘slow buffering’. Do you refer to the time it takes the video to start playing from the time you press Play (the time you watch it filling the player’s buffers) ? Are you using subtitles? May I see the XML (Get Info -> Show XML … use ‘code’ paragraph formatting at top of the reply window so the forum doesn’t ‘eat’ the XML)?
Thanks for taking the time and helping me on this, please see my response below
I did and you are correct, I don’t see the error anymore
If you have other tasks, then yes, this will impact them as transcoding makes high demand on 2-3 threads (cores). Typically 2 cores will take a full 100% 'hit
This computer has just running Plex and sonaar. There is really nothing else.
I googled and it look like Myth is now bundle with Plex(I could be totally wrong), that why I mentionned Myth before.
Please further define what you mean by 'slow buffering
If I play any movies, with or without subtitle, it will play for 5second and then stop for another second which makes the movie impossible to watch
Myth is not bundled with Plex. MythTV is a totally different piece of software.
If you are part of the DVR beta / running the DVR beta binaries, then Yes you are seeing the DVR functions like what MythTV provides. I used to use Myth until coming to Plex. Now, myth is long gone.
If you’re not using a DVR functionality, I would highly recommend running normal PMS (current is 1.3.3)
When DVR runs, it is my understanding, PMS will transcode inbound as it needs for storing. If you’re also performing transcoding at the same time, you will see the extra load of two transcode tasks on the CPU. DVR activities will not be reflected in the PMS log files. PMS DVR and PMS 1.3.3 are currently two different development efforts. At some point in the near future, Engineering will merge DVR into the normal PMS mains and it will be fully integrated. I personally am waiting to see how that turns out and will have a lot to learn. (my hands are sufficiently busy here for now ).
Please do a “Get Info” and then “Show XML” for one of (or the) items which are slow. What you are describing should not be this way so there’s something we’re not seeing yet.
Please look at the XML. Do you see the subtitles? VOBSUB. These are very CPU-expensive. If you need to display subtitles and PMS has to put them with the image, it has to ‘burn-in’ those because they are bitmap graphics. SRT subtitles are text and much easier to deal with.
This is why we’re seeing your CPU run at 500x real time and then drop to 20x and then sleep, then shoot up again. It’s dealing with subtitles.
Are those subtitles required? An option is to use some of the 3rd party programs to convert them to text. It will take a huge load off your CPU.
