Indication of media not scraped by PMS
It would be super great to be able to quickly tell that PMS has not been able to identify certain media.
For example, I have a certain number of movies in my library but plex is not showing that same number. It is a huge pain to have to figure out what is missing.
Just of the top of my head. The file/folder view could have an alert next to something that has not been able to be identified.
Thanks Plex Team!
https://forums.plex.tv/topic/87745-find-unmatched-items/
/Tommy
Do you mean movies not found my the Scrapper or movies that has bin found and added to PMS but have not downloaded metadata? If first then try the Plugin dane22 linked to.
If you mean second i would love to know it too. Sometimes i have Episodes where no metadata had been downloaded.
Maybe the sister to the FindUnmatched plug-in?
https://forums.plex.tv/topic/95148-rel-findmissing-files/?p=555699
/T
Cool, i will test it
Would be nice if it was a standard feature. thanks for linking to the plugin though :wink:
Sent from my Nexus 5 using Tapatalk
Thanks dane that should be a great tool.
I was referring to media that had not been found at all, but I do have a few stragglers that refuse to have the proper metadata downloaded.
But that was the first tool
Sent from my GT-I9505
It definitely helped to fix my problem, I was just clarifying for Skycryer. The pulgin works great, thanks for your support!
