Infinite buffering when opening files on Nvidia SHIELD player (and other issues)
This happens on all of my Android TV devices. Shield, HiSense H8G, and Tivo Stream 4k. I’d say 1 in 5 times a try to start a direct play video it will work. I can usually get it to work by stopping and start the video a few times if the spinning circles lasts more than a few seconds. Resuming works just as poorly. This is with every file. Doesn’t matter if it’s H.265, H.264, DD, DTS, TrueHD, DTS-HD MA, Atmos, etc.
This has been going on for months, over the course of numerous updates and hasn’t gotten any better. Looks like some users have been having issues linger than that.
Having the same issue. Even updated to the beta program to see if that fixes it. Nope.
I get the same issue for Months now … it is really frustrating paying for a plexpass, having one of the best android TV device (Shield) and they do not figure it out.
Playing through an old 2016 Tizen TV, it is working, playing on smartphone, tablet is working. But on shield even a 1080p is sometimes hanging …
As the other people no matter if direct play, transcode, etc sometimes working well, sometimes hanging.
If you can, the build below might solve your issues:
Arm64:
https://artifacts.plex.tv/android-experimental/8.26.0.28838-bcd4f257/PlexForAndroid-8.26.0.28838-bcd4f257-Arm64v8aGooglePlayStdExo.apk
Armv7:
https://artifacts.plex.tv/android-experimental/8.26.0.28838-bcd4f257/PlexForAndroid-8.26.0.28838-bcd4f257-Armv7aGooglePlayStdExo.apk
I have tried hte Arm7 version for my shield TV 2019
The situation seems to be a lot better. I’m testing several 4K movies I’m now able to play in direct stream. This is working for AC3 5.1, DTS, DTS MA, BUT still hangs for TrueHD and True HD Atmos ! The 2 last ones are not working
But there is progression
can we get your android logs after trying to play one of those.
Since the latest update, I have not had any issues on either my Shield or Chromecast 4K devices. I’ve had other users tell me their Firesticks are working again as well. When my family and friends are happy and streaming, I am happy. Thank you to all the dev’s working on this. I know it’s a tiring job with little reward most of the time (from one coder to another).
I have been having this issue for months. Why isn’t this fixed as yet? I am on the most recent version ad still have the problem.
I’m sorry it has just been hard to reproduce ourselves and figure out. Have you tried the releases linked a couple of posts above. Would you mind sharing recent app logs with one of those versions
Installed the Arm64 version above and initial test is worse than the previous version.
Just restarting Shield to try again.
Nope still worse.
Interestingly this version doesn’t seem to load any buffer. At least I cannot see any buffering on the playback bar for the file.
Edit: tried again and now it’s buffering. Seems very random. Playback OK at the moment. 20 mins in with buffering keeping up and playback remaining fine.
All I know is that my system worked fine a few months ago, and has recently become very unstable.
Playback with the plex client on the LG tv still seems to be fine (but missing atmos, unlike the shield).
Tried 2 other videos which have so far required trying a few times to start playback, but when started have been fine. This is with the Arm64 apk listed above.
can you provide android logs when they are not starting
Hi BigWheel. I’ll certainly try :slightly_smiling_face:
I’m sharing data with Plex so is there anything in that data at all to start with?
Cheers.
If you are referring to crash data it is sent to us but only when there is a app crash afaik. if you mean playback data Opt In as described in our privacy policy then that is all generalized and anonymous so we would not be able to get specifics to any users particular playback events.
You are welcome to message me the logs by clicking on my username/avatar and clicking on message button if you are concerned about posting them publicly here.
Plex on Shield Pro/Android is consistently unreliable for me. Things that play fine via web just won’t ever commence playback on shield.
Sometimes restarting the shield can fix it, but normally not.
Latest logs
logging.txt (4.9 MB)
Thanks BigWheel.
I’m not sure how to retrieve the logs from a Shield TV unfortunately.
@P5y logs can be obtained by following this procedure: https://support.plex.tv/articles/201573117-android-android-tv-fire-tv-logs/
Android TV & Fire TV
When you need to retrieve logs from your Android TV or Amazon Fire TV device, you can do so by turning on logging, reproducing the issue, then retrieving the logs.
Reproduce the Issue and Grab Logs
When you enable network logging in the Android TV app, you’ll be able to access device logs over your local network for the next 20 minutes. You’ll need to grab your app logs right after reproducing the issue. To do so:
  1. Reproduce the issue you’re experiencing
  2. In the app, go to Settings > Advanced > Network Logging and turn ON the setting
  3. In a web browser on another device/computer, go to http://[IPofAndroidDevice]:32500/logging (the exact URL to use will be displayed at the bottom right of the screen)
  4. Save the browser page as a text file or copy-paste it into a text file and save
Thank you! This release fixt the problem here. I shall test some more but it looks that it is gone. Shield 2019 Tv Pro user.
For me this problem only occurs on the Shield Pros (2019).
We don’t see this issue on the other Shields, and I don’t think I’ve witnessed it in the Pro (2017) model.
This build seems to have cleared up the issues for me, though I haven’t had much playtime with it yet.
Yeah, unfortunately my problem came back. Not sure what’s going on. It’s definitely happening only my shield.
