Initial server setup wizard is not starting up
Server Version#: 4.69.1
I am running plex via docker from Docker
I am able to start the server and according to the logs even claim the server via claim code.
I see this in the log:
Server claimed successfully, navigate to http://serverip:32400/web to complete plex setup.
But when I navigate to http://localhost:32400/web
it just takes me thorugh the login, which succeeds, but the server setup wizard is skipped, and when I click media all I see is “Add your media to Plex” and button “Get Plex Media Server”
I have even tried using local IP address “http://172.5.1.127:32400/web” and the same result.
I have read numerous on-line forums for people having the same problem but nothing works for me. I have tried re-setting the docker container as well to run from scratch, and again same result.
What am I doing wrong?? This shouldn’t be this hard :frowning:
UPDATE:
Ok after trying and retrying over and over for over 2 hours I somehow got it to work… I don’t know if it is just a co-incidence, but when I used the address http://127.0.0.1/web that seemed to have triggered the server setup.
I don’t know why I was struggling so much before, I haven’t done anything different. It seems weird to me that localhost wouldn’t have worked but 127.0.0.1 did work.
The server setup wizard only starts if the server is accessed from within the local network.
But since the above address is not within a “private” IP range, there is no local network.
localhost is not an IP, but a hostname.
I assume, you’d need a fitting entry in the hosts file for it to work.
