Problems with setup
Server Version#: 4.106.2
Player Version#: No idea
I had to move Plex Server onto a different computer and it doesn’t work. I have uninstalled it at least 20 times. No matter what I do after installing I don’t get the INSTALL WIZARD to help set up the new server and whenever i log in it tells me to download Plex Server.
What am I doing wrong???
In order to complete the setup you need to open your Plex Media Server through its local IP.
If you’re on the same machine… open http://127.0.0.1:32400/web in your browser. If you’re on a different machine inside your home network, use http://[PMS IP address]:32400/web instead. This will bring up a wizard/dialog where you can name your server and link it to your Plex account (as well as creating your first libraries).
Once you “claimed” your server (=linked it to your Plex Media Account), you’ll also be able to access it from other Plex apps or via http://app.plex.tv/desktop.
https://support.plex.tv/articles/200288586-installation/
If it’s still not showing the installation wizard, you might want to check there’s no leftovers from a previous installation on the new machine:
https://support.plex.tv/articles/201198426-restart-plex-media-server-setup-from-scratch/
Nothing seems to work. How do I find the IP address for Plex?
Found the IP address… That didn’t help though.
You’re looking for the local IP address of the computer running your Plex Media Server.
If you’re on the same machine you can use 127.0.0.1. If the server is hosted on a different machine inside your home network but you’re not sure about the ip address, you should be able to find it in your router’s configuration pages.
Everything I do takes me to the same place. “Get Plex Media Server” done that 20 times.
Can you walk me through what exact steps those are?
There were a number of options floated in my previous post, so I’m not sure which of them you tried (or if you maybe attempted some shortcut, skipped some).
I have tried them all… I have tried deleting the plex file off the hard drive so I could do a clean install. Same results.
To let you know I have used Plex for about 10 years without any problem. Is there anything in the registry I should delete?
As per the link above:
HKEY_CURRENT_USER\Software\Plex, Inc.
Yes… I removed that line from the registry and re-installed and it works. Thank you for your help. Now this old man can watch my movies again.
