Install guide for Debian 11
Server Version#:latest
Player Version#:any
Hi team,
Could you please update the install guide for Debian 11? I’m getting apt-key error, trusted.gpg.d should be used instead starting with Debian11.
Thank you,
ioan
@ioanstan
I will update the procedure.
Debian 11 just came out.
Hi ChuckPa, thank you. While waiting for Debian11 repo guide, would it be any problem if we do plex manual update on Debian 11? In other words, is Debian 11 certified for running Plex Server?
Cheers,
ioan
Plex runs just fine with Debian 11.
As for the ‘procedure’. I have unfortunately been swamped with Synology DSM 7. it’s been a “more than both hands full” task.
apt-key is still operating albeit “deprecated” which means it will stop functioning at some point in the future. For right now, all is ok – or do you have a counter-example ?
Thank you, understood,
ioan
