Installing OpenPHT on Ubuntu 14.04
I have a fresh install of Ubuntu 14.04 with all the latest updates.
I downloaded openpht_1.6.2.123-e23a7eef-trusty_amd64.deb and tried to install it and got a bunch of errors.
Has anyone been able to install OpenPHT on Ubuntu 14.04?
sudo dpkg -i openpht_1.6.2.123-e23a7eef-trusty_amd64.deb (Reading database ... 212854 files and directories currently installed.) Preparing to unpack openpht_1.6.2.123-e23a7eef-trusty_amd64.deb ... Unpacking openpht (1.6.2.123+e23a7eef~trusty) over (1.6.2.123+e23a7eef~trusty) ... dpkg: dependency problems prevent configuration of openpht: openpht depends on libboost-system1.54.0; however: Package libboost-system1.54.0 is not installed. openpht depends on libboost-thread1.54.0; however: Package libboost-thread1.54.0 is not installed. openpht depends on libgcrypt11 (>= 1.4.5); however: Package libgcrypt11 is not installed. openpht depends on libglew1.10 (>= 1.10.0); however: Package libglew1.10 is not installed. openpht depends on libgnutls26 (>= 2.12.17-0); however: Package libgnutls26 is not installed. openpht depends on libtinyxml2.6.2; however: Package libtinyxml2.6.2 is not installed.
dpkg: error processing package openpht (--install): dependency problems - leaving unconfigured Processing triggers for gnome-menus (3.13.3-6ubuntu3.1) ... Processing triggers for desktop-file-utils (0.22-1ubuntu5) ... Processing triggers for bamfdaemon (0.5.3~bzr0+16.04.20160701-0ubuntu1) ... Rebuilding /usr/share/applications/bamf-2.index... Processing triggers for mime-support (3.59ubuntu1) ... Errors were encountered while processing: openpht
Try running ‘sudo apt-get install -f’ to see if ubuntu can find the dependencies itself.
Does not work:
nuc@nuc:~/Downloads$ sudo dpkg -i openpht_1.6.2.123-e23a7eef-trusty_amd64.deb [sudo] password for nuc: (Reading database ... 218883 files and directories currently installed.) Preparing to unpack openpht_1.6.2.123-e23a7eef-trusty_amd64.deb ... Unpacking openpht (1.6.2.123+e23a7eef~trusty) over (1.6.2.123+e23a7eef~trusty) ... dpkg: dependency problems prevent configuration of openpht: openpht depends on libboost-system1.54.0; however: Package libboost-system1.54.0 is not installed. openpht depends on libboost-thread1.54.0; however: Package libboost-thread1.54.0 is not installed. openpht depends on libgcrypt11 (>= 1.4.5); however: Package libgcrypt11 is not installed. openpht depends on libglew1.10 (>= 1.10.0); however: Package libglew1.10 is not installed. openpht depends on libgnutls26 (>= 2.12.17-0); however: Package libgnutls26 is not installed. openpht depends on libtinyxml2.6.2; however: Package libtinyxml2.6.2 is not installed.
nuc@nuc:~/Downloads$ sudo apt-get -f install Reading package lists... Done Building dependency tree Reading state information... Done Correcting dependencies... Done The following packages will be REMOVED: openpht 0 upgraded, 0 newly installed, 1 to remove and 13 not upgraded. 1 not fully installed or removed. After this operation, 89.7 MB disk space will be freed. Do you want to continue? [Y/n] y (Reading database ... 218882 files and directories currently installed.) Removing openpht (1.6.2.123+e23a7eef~trusty) ... Processing triggers for gnome-menus (3.13.3-6ubuntu3.1) ... Processing triggers for desktop-file-utils (0.22-1ubuntu5) ... Processing triggers for bamfdaemon (0.5.3~bzr0+16.04.20160701-0ubuntu1) ... Rebuilding /usr/share/applications/bamf-2.index... Processing triggers for mime-support (3.59ubuntu1) ... Processing triggers for libc-bin (2.23-0ubuntu3) ...
nuc@nuc:~/Downloads$ sudo dpkg -i openpht_1.6.2.123-e23a7eef-trusty_amd64.deb Selecting previously unselected package openpht. (Reading database ... 217832 files and directories currently installed.) Preparing to unpack openpht_1.6.2.123-e23a7eef-trusty_amd64.deb ... Unpacking openpht (1.6.2.123+e23a7eef~trusty) ... dpkg: dependency problems prevent configuration of openpht: openpht depends on libboost-system1.54.0; however: Package libboost-system1.54.0 is not installed. openpht depends on libboost-thread1.54.0; however: Package libboost-thread1.54.0 is not installed. openpht depends on libgcrypt11 (>= 1.4.5); however: Package libgcrypt11 is not installed. openpht depends on libglew1.10 (>= 1.10.0); however: Package libglew1.10 is not installed. openpht depends on libgnutls26 (>= 2.12.17-0); however: Package libgnutls26 is not installed. openpht depends on libtinyxml2.6.2; however: Package libtinyxml2.6.2 is not installed.
dpkg: error processing package openpht (--install): dependency problems - leaving unconfigured Processing triggers for gnome-menus (3.13.3-6ubuntu3.1) ... Processing triggers for desktop-file-utils (0.22-1ubuntu5) ... Processing triggers for bamfdaemon (0.5.3~bzr0+16.04.20160701-0ubuntu1) ... Rebuilding /usr/share/applications/bamf-2.index... Processing triggers for mime-support (3.59ubuntu1) ... Errors were encountered while processing: openpht nuc@nuc:~/Downloads$
You can install a package and get dependencies from repositories with
sudo gdebi package.deb
If you already installed the package with missed dependencies, you can download and install dependencies automatically with
Also available is a graphical version gdebi-gtk, linked to .deb nautilus right click action “Open With GDebi Package Installer”.
Thank you. I made a mistake of installing the wrong version of OpenPHT for Ubuntu 16.04. I had Ubuntu 16 and was installing OpenPHC for 14.04
Is there anyway to make OpenPHT autostart in full screen in Ubuntu?
