Installing Plex on a OpenSUSE Leap 15 (64 bits)
Thanks! Did what you said, and got it up and running:
`# systemctl status plexmediaserver``
  ``● plexmediaserver.service - Plex Media Server for Linux``
  ``           Loaded: loaded (/etc/systemd/system/plexmediaserver.service; enabled; vendor>``
  ``           Active: active (running) since Sat 2018-08-25 11:06:10 EDT; 1min 52s ago``
  ``          Process: 2068 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_A>``
  `` Main PID: 2076 (Plex Media Serv)``
  ``    Tasks: 4 (limit: 4915)``
  ``   CGroup: /system.slice/plexmediaserver.service``
  ``                   └─2076 /usr/lib/plexmediaserver/Plex Media Server``
  ``        Aug 25 11:06:10 mofi systemd[1]: Starting Plex Media Server for Linux...``
  ``        Aug 25 11:06:10 mofi systemd[1]: Started Plex Media Server for Linux.``
    Now the only problem seems to be that my browser (Firefox 60.1.0) cannot see the Plex server running neither through [https://app.plex.tv/desktop](https://app.plex.tv/desktop)        , nor through . I suspect OpenSuSE Leap 15 has changed something with the firewall as well - please let me know if have any further recommendations.
Thanks,
Julio
To be frank, I just cooked an Leap15 for this on VMWare, and had the FW switched off :slight_smile:
Does it work, if you switch off the FW as a small test?
And checked the install script…
No entries in that for the Firewall, so guess that’s a manual thing, where you have to open up the ports your self
https://support.plex.tv/articles/201543147-what-network-ports-do-i-need-to-allow-through-my-firewall/
Did better: turned off the firewalld daemon altogether (it is disabled and inactive), rebooted, and … no luck!
`# systemctl status firewalld.service``
  ``● firewalld.service - firewalld - dynamic firewall daemon``
  ``           Loaded: loaded (/usr/lib/systemd/system/firewalld.service; disabled; vendor >``
  ``   Active: inactive (dead)``
  ``     Docs: man:firewalld(1)``
  ``        Aug 25 12:13:06 mofi systemd[1]: Starting firewalld - dynamic firewall daemon...``
  ``        Aug 25 12:13:06 mofi systemd[1]: Started firewalld - dynamic firewall daemon.``
  ``        Aug 25 12:41:12 mofi systemd[1]: Stopping firewalld - dynamic firewall daemon...``
  ``        Aug 25 12:41:14 mofi systemd[1]: Stopped firewalld - dynamic firewall daemon.`
    Yet, the PMS process is running
# systemctl status plexmediaserver.service
`        ● plexmediaserver.service - Plex Media Server for Linux`
`           Active: active (running) since Sat 2018-08-25 12:00:18 EDT; 37min ago`
`         Main PID: 1835 (Plex Media Serv)`
`                   └─1835 /usr/lib/plexmediaserver/Plex Media Server`
`        Aug 25 12:00:18 mofi systemd[1]: Starting Plex Media Server for Linux...`
`        Aug 25 12:00:18 mofi systemd[1]: Started Plex Media Server for Linux.`
    so it has me completely confused.
Thanks,
Julio
Powered Leap15 up again, and it works nicely, from LAN
So…does it work directly from the box, browsing to http://127.0.0.1:32400/web ?
I have a box that was a former version of OpenSUSE Leap (42.2, I believe) and I pushed it up to Leap 15. I created no symbolic link as indicated here, there was no symbolic link, and I have not only had no issues with operation but upgrades of PMS have gone fine as well.
For clarity - this box has had PMS on it for 18 months or more and I opted to do an OS upgrade because the box was actually powered off for a short bit. Rather than do all of the updates and such, I just downloaded the Leap 15 media and did an in-place upgrade right over the top.
Thanks. Mine is an installation of OpenSuSE Leap 15 from-scratch . The Plex Media Server installs with no complaints, runs, but … I cannot connect to it even from the same host. I tried disabling the firewall, enabling it and adding plexmediaserver as a trusted service to the home zone, adding each and every one of the ports suggested in the documentation, … rebooting in-between, … nothing appears to work for me.
  I suspect there is something going on with the firewall, but I am unable to pin it so far. I tried disabling the firewall, enabling it and adding plexmediaserver as a trusted service to the home zone, adding each and every one of the ports suggested in the documentation, ... rebooting in-between, ...
Nothing appears to work for me, so far.
To get to the “solution” I installed a fresh Leap 15, and it works here…
So next Q: Are you sure the networking of your box is configured correctly, like default GW etc?
And is IP V4 enabled?
The origen file was/is mostlikely kept when upgrading, or ?
https://server:32400/web
Are you using the “S”?
Absolutely: GW points to my router, and everything else works just fine.
Then log time…
Zip the logs, and upload here
Without the symbolic link PMS did not run (it would start, then die).
Thanks,
Julio
Until a server is claimed, https doesn’t work, AFAIK
Not using https, but http. Regardless, neither one works.
Thanks,
Julio
Yes, clearly. Thanks – Julio
I’m all ears but … which ones? Thanks – Julio
