Intel NUC NUC6i3SYH (i3-6100U)
I have PMS on my regular desktop, since i found Plex. Sometimes when wifey wants to look at her series on Plex on iPad while i’m gaming for example, my CPU spikes to 100% obvious while gaming.
Since Plex are heading for Kodi now, i’m looking to give my parents access to my Plex Share.
So i’m looking for a NUC that would suit my needs, and to be come my Plex Server.
I’m looking at Intel NUC NUC6i3SYH (i3-6100U - 3904 passmark)
Would it be enough? or do i need the i5 one? And for you who have an NUC, hows the noise from it during transcode. Is it much?
WIll be having my Library on my PC sharing as a NAS.
Appreciate your help.
Only have 720p content, Wasnt the theory 2000 passmark per transcode? So i do need a i5 for be able to transcode 2 720p streams?
Trancode 720p down to what? If you already at 720p for your content would you not be direct playing/streaming
According to PlexPy PLEX transcoded a 720p movie when my mate streamed it to his ChromeCast.
I suppose if its a highbit rate 720p it would still transcode. The rule of thumb is 720p trancode would be 2000 passmark rating. With that NUC you will be able to do two streams.
PlexPy tell you what it is transcoding down to or the same 720p?
Video
Stream: transcode
Width: 1280
Height: 536
Codec: h264
ahh. never mind then, cause he has a sucky tv plex transcoded it?
So yeah 2 streams with that NUC. Go for this NUC if you can afford it:
Intel NUC6i7KYK
CPU Passmark
So the i3 one would be able to handle 2 streams fine?
2 720p streams.
@lqvnguyen said:
2 720p streams.
Thanks, orderd one now :slight_smile: hopefully it comes tomorrow :slight_smile:
Just bought the NUC6i7KYK also. Has a Samsung SSD too. 8GB RAM. Awesome, very happy. Syncing to devices takes less than half the time compared to my previous Lenovo i3 mini-PC. I use it as a dual PMS and OpenPHT client, plugged directly in to TV via HDMI. Loading of movie posters in OpenPHT is lightning fast, almost instantaneous. PC cold boots in ~30 seconds (faster if I use sleep function which I’m still a little uncertain about). Fan noise during transcodes/sync isn’t too bad although I don’t mind a bit of light noise for 4 minutes while it syncs a movie.
I do intend to load it up much as I can to find it’s breaking point. Multiple simultaneous transcodes and see what that does to the Open PHT UI.
200Mbps fibre broadband (up & down) coming in a few weeks :slight_smile:
I’m really happy with the NUC. Can transcode 5 streams for me at the sametime.
@trumpy81 said:
I presume you simply want to alleviate the CPU usage while gaming issue. In which case the NUC should achieve that at least.
The Intel NUC NUC6i3SYH (i3-6100U) would be good for a single low-med bitrate 1080p transcode. If your media Direct Plays without transcoding, then you should not have an issue with using that NUC. If more transcoding is a requirement, then you should look at the i5 NUC or better.
Leaving the files on the PC would mean that you would have to leave the PC and NUC running 24/7 in order to always have access to Plex.
It might be worthwhile investing in a USB drive to attach to the NUC and have the latest media saved to that and any older media saved on the PC. That way you could turn off the PC when it wasn’t needed and you would still have access to the latest media.
This is all fine but are you saying the same applies while gaming concurrently ? A modern top end game would hardly run smoothly at high res on an i3 even without plex transcoding. I dont see how both can co-exist on the same hardware and run concurrently. I just bought an i7 NUC and even that is not well regarded as a gaming machine (would cope just about but not at full res). Or are we saying the NUC is for Plex only and gaming stays on the desktop.
I think I will buy one machine of this ones ( INTEL® NUC KIT NUC6i3SYK) what can I expect from transcoding in plex? i have 1080p movies!
I think you can have 2 streams transcoding at the same time minimum.
https://www.cpubenchmark.net/cpu_lookup.php?cpu=Intel+Core+i3-6100U+%40+2.30GHz&id=2623
With a Passmark of 3603 you will be lucky to get two, based on the rule of thumb of 2000 per transcode of 1080p movies: https://support.plex.tv/articles/201774043-what-kind-of-cpu-do-i-need-for-my-server/
Very roughly speaking, for a single full-transcode of a video, the following PassMark score requirements are a good guideline for the following average source file:
  • 4K HDR (50Mbps, 10-bit HEVC) file: 17000 PassMark score (being transcoded to 10Mbps 1080p)
  • 4K SDR (40Mbps, 8-bit HEVC) file: 12000 PassMark score (being transcoded to 10Mbps 1080p)
  • 1080p (10Mbps, H.264) file: 2000 PassMark score
  • 720p (4Mbps, H.264) file: 1500 PassMark score
I have connected my Nuc to the local network, I have installed the PIex app on my 4k TV but when I tried to run a 4k UtraHD movie (67 GB release) I got a message saying that server is not powerful enough, also my PMS is running on Linux Mint. Could sombody tell me where could be the problem?
