Server Version#: Version 1.18.4.2171
Player Version#: Plex Web Version 4.12.3
Basically looking for help in determining how to fix the immediate crash that happens in Plex when I enable Hardware Transcoding. I’m aware of the other thread that @sa2000 has been working on with several other users and tried their suggestions- it did not work. Hardware transcoding (QuickSync) causing server crash
My GPU is an Intel Iris Plus Graphics 650 Adapter
How to reproduce:
- Enable Hardware Transcoding- either or both options.
- Restart services
- Start a sync or conversion
- Within 30 seconds to a few minutes Plex crashes- I see this via Plex Media Server Service alerting that Plex has stopped and will be restarted.
- Looking through the logs doesn’t tell me anything that I recognize. I see the sync/transcode request and then immediately afterwards a crash dump alert.
Attached to this request are an Intel Driver and Support Assistant output- I am running the current drivers for my NUC- tried the newer ones that @sa2000 referenced in the other thread- (26.20.100.7584) when they did not work I rolled back as the newer driver was not certified for my system- I had to “force” it in to test with.
Lastly my system is headless- I use RDP to interact with it. I also run Plex as a service using Plex Media Server Service 1.1.7.0
Please help me with next steps to either gather logs for additional troubleshooting, or additional steps to try to diagnose what I am seeing happen.
ThanksDetailed-System-Report.zip (2.8 KB)
