Hello
Is there anyway to integrate iptv link into plex like your able to with Emby?
Hello
This is how to do it with Plex: GitHub - Threadfin/Threadfin: an M3U proxy for Kernel/Plex/Jellyfin/Emby based on xTeVe
Plex won’t take an m3u like Emby but Threadfin will, and it will emulate an HDHomerun device for Plex.
Any chance you can explain how to use threadfin? Does it need to be loaded onto the NAS device?
Any help would be appreciated thank you
Typically it would be on the same machine that is running the Plex server but it doesn’t need to be. I don’t use a NAS device, but I know that at least some of them support Docker containers. What brand or OS is your NAS?
I am using a Qnap, thank you any guidance is appreciated
so I figured out how to get the threadfin added to Qnap by using Docker image, but from there I am lost
Hopefully someone who uses QNAP chimes in but the setup of Threadfin is web based like Plex. So in a browser go to the NAS’s local IP with the port (default is 34400) at the end. example: http://192.168.1.254:34400/web/
Threadfin is a continuation of xTeVe so they still link to the xTeVe documentation which may help:
