First off apologies if this is the wrong section. Wasn’t sure if it should be here or in channels section!
I have a QNAP TS451+ I have installed the PMS on here.
I am trying to get IPTV channels to work.
I have installed Cigaras IPTV.bundle app. The way I installed it was to upload the IPTV.bundle folder to the share/download folder via FTP
then via terminal I moved the folder to
[~/Library/Plex Media Server/Plug-ins] as there is no way I can see to access this folder via ftp or via the file manager in QNAP web portal.
I also uploaded a m3u playlist file. I know this works as I have tried it in vlc.
When I goto Channels and select IPTV I see all the channels but when I try selecting one I get an error that playback of media is unsupported. I have tried using the default playlist that came with IPTV.bundle and get the same error
the streams end with a .ts (transport stream) format. I have also tried .m3u and .m3u8 streams and its the same for all of them.
I have also done a quick install on windows to test and get the same error.
I have installed Channel Pear. When I use one of the channels they already have (BBC One) it worked fine.
When I tried to add my own media source using the url it all checked out fine but get the playback error via Plex.
First of all, the first plugin dir you tried was the correct one.
Secondly, I urge you to check out WebTools (See my signature), that can assist you in the future with installing 3.Party plugins
And lastly, since this is not a PMS issue, but a Channel issue, go here to locate the relevant support thread: forums.plex.tv/discussion/200017/support-find-my-plug-in-here-for-support#latest
Dear all
I have the NAS Qnap TS-451+ also and I have installed the webtools. When trying the preinstalled channel in the IPTV application from webtools it works fine. Now I have added my own channels list from my tuner within same network (the same M3U list works perfectly with VLC)
I can see the list of channels showing now in Plex IPTV but when I click on them no video is coming at all. I can see a light starting on my tuner which usually means that someone is remotely accessing the tuner but no video on plex.
Any idea what I am missing ??
Thanks a lot
Regards
