Is Att Uverse blocking PMS?
I have had plex working remotely for a couple years and suddenly 3 weeks ago it just quit… cant stay connected… Ive tried port forwarding and still it will not stay connected… Is anyone else experiencing this problem with Uverse (gateway Arris bgw210) if you have a solution to this please let me know
If you check the other posts that come up below your own, it looks like this is an ongoing issue specifically with AT&T.
Sounds like they use a certain type of firewall rules that are problematic for incoming anything.
I’d suggest dumping the AT&T rented equipment and picking up a separate modem to see what’s up with it.
