There seems to be no options folder for playlists, only the movie library, So I ask, Is there anyway of re-arranging the movies in my playlist alphabetical? this would seem like a very basic function. every time I add movies, I have to delete my old playlist and reload them all from the main library movie list alphabetically, but then if and when I add a few more titles, it just puts them at the end of playlist when I add them. I’m spending far to much time just trying to organize my 8 different playlist, with some having over 300 movies into any coherent order to find them easily, an Alphabetizing is the simplest for of all lists.
how did you create the playlist. if they are smart playlists which was sorted by name when you created it will stay that way.
in the web app you can manually arrange them by grabbing the handle on left side of an item.
there is not a column sort if that is what you are asking
I’m just sort of curious if you are just viewing things alphabetically anyway why do you need a playlist at all? why not filter by whatever you are viewing them by
