Is there a way to embed a feature into editing interface that will allow renaming the file see below
Is there a way to embed a feature into editing interface that when renaming the file also Inserts the name into the file property’s details IE name of the file.So say you need to put in Directors cut, Unrated, Extended Cut … If any thing happens and you have to redo the DB you don’t have to go thru your whole DB and input all that data again because your files always
seem to list by that even if you file name is what ever it is.
Also can there be a way to add the option to open the folder containing the file in a new window within the editing interface. it make it much easier to modify the files.
Early 2021 clean-up: duplicate
