Issue when try to save modification on library
Server Version#: 1.42.2.10156
Player Version#: 4.155.0
Can you see if this happens with the local web client (i.e. http://127.0.0.1:32400/web)?
Found the problem which is in the latest web release (4.155.0) - we’ll be releasing a fix for this soon.
great !! ! thanks
The local bundled version will still work fine, it’s just app.plex.tv that is affected.
ok I’ll try
Should be resolved in 4.156.0, thank you for the report!
Hy,
I still have this issue even with latest web version : 1.456.0
Can you please provide the full server logs.
Plex Media Server.zip (315.9 KB)
Thanks!
I’m a bit confused how you’re able to get into this scenario, the scanner and agent in your request are not compatible and would never work correctly, the web interface should be preventing you from even selecting this combination.
Can you try and change the agent and scanner to the correct values and see if that helps?
For this specific library of yours (the Concerts one) the scanner should be set to “Plex Movie” and the agent to “Plex Personal Media”.
Can you try that and see if it resolves your issue?
yes it works with those options. thanks
Great thanks!
When PMS 1.43.0 goes public then this should also help prevent selecting these incorrect agents as those legacy ones will no longer be listed by default.
