Server Version#:1.32
8.7639
So I’m having a weird issue with continue watching on the desktop app only. It will only show up to 4 of my continue watching items, if I mark one as watched one that’s hidden will become visible. If I go to web player all continue watching are there. My settings for weeks watched and number showing is very high.
Hi. I have the same problem (Windows, Chrome) but in my case Plex will only show 5 items. If I start watching something else it will add it to the ‘Continue watching’ section and erase the last one. If I then finish watching something or remove it by hand the hidden item will reappear.
Anyone knows of any solution for this?
To add to this, I have the same problem, except the quantity varies, sometimes there’s 3, sometimes 2, sometimes only 1.
In every case, it is not related to continue watching settings, as I watch things, I then see a different item that should be shown on the list. There’s clearly some sort of weird artficial limit being added where it’s not showing the full quantity of valid items.
I’m also having this issue, are there any noted fixes?
Do all of you have those set high?
