Issue with IDX/SUB Files on Specific Videos
Good morning, I know that Plex has always had an issue with idx/subs to a certain degree, but I was wondering if anyone knew a fix to my specific issue.
I have TV Shows that are in Japanese that use Japanese subtitles, and the subtitles where converted from .xml/png to .idx/.sub. The subtitles play perfectly fine in PotPlayer/VLC, and interestingly enough, SOME of the videos in plex show the subtitles and play without issue, while the others wont see the subtitle file.
As you can see from that image, the subtitles are named correctly (the same as the mp4) and plex is showing that there are Japanese subtitles, which is correct. In the picture I also included the size, as you can see, the total size of the idx/sub is about 2mb. I am only stating this because I remember there being an issue with sub/idx files bigger then 25mbs.
Now if I go to another show, Homeland, in this instance, the subtitle is named the correct way, and has the same relative size, but plex does not see it at all:
It makes no sense to me. If I try to manually upload the sub/idx file it tells me it exceeds the 1mb limit, so I can’t, but that still doesn’t explain why one show sees the subtitles and another doesnt.
Now to make things even more weird, I thought, okay maybe there is something different about the way I converted the The Blacklist subtitles as opposed to the Homeland subtitles. So I moved the Homeland E01 subtitles to a different folder, and copied The Blacklist S1 subtitles to the Homeland folder and renamed it…
So just so we on the same page, now Homeland E1, has the working subtitles of The Blacklist S1, and now plex shows that Homeland has subtitles. Of course they are the wrong subtitles, but subtitles non-the-less.
So then, I deleted the subtitles and put the original Homeland E1 subtitles back, and guess what? The subtitles are still seen, and WORK. So now the correct subtitles are playing and plex sees a subtitle file… what in the world?
I am running Plex on a Windows 10 box, with the newest Plex Media Server 1.22.1.4228.
Tested Subtitlest.zip (1.8 MB)
Above are the tested subtitles from the test.
Any help would be greatly appreciated!
Go to the top level of the Homeland show (easiest done by clicking on the title Homeland).
Then Refresh Metadata of this show.
Wait a few minutes, then reload the web app in your web browser by pressing F5.
That does not fix the issue.
Again if i rename the The Blacklist subtitles and refresh it will show up, and if i put the original subtitles back and refresh itll work. But for all the subtitles I do not do that with, nothing shows up
I took another look at your screen shot:
You are not using subfolder per season. External subtitles don’t show up reliably without these subfolders.
That also does not fix the issue. I did that with every season and refreshed metadata and still no japanese subtitles.
Here is an example of a show already in that format.
As you can see, the english subtitle shows without issue, but the japanese subtitle does not. It is in Season format.
Are you already using the new tv show scanner/agent? (Don’t change it now!)
Have you tried to mux the new subtitles in? I remember difficulties with external image-based subtitles in the past.
