Issues with Season 5 & 6 of a show
Server Version#: 1.109.0.329-ea562b95
Player Version#: 2025.19.0 (1132) iOS
I have a bizarre issue I haven’t seen before, I have 6 seasons of the following show:
Faster with Newbern and Cotten (2020) {tvdb-373670}
Seasons 1-4 are fine, all episodes match the TVDB Aired Order and show metadata. Seasons 5 and 6 however do not pull any information. I have verified all episodes in Seaosn 5 and 6 are named appropriately. Strangely, the episode ordering for the show under advanced displays “tvdbAiring (unavailable)”. However if i navigate to the show in TVDB it has all the information for Season 5 and 6 under Aired Order.
I would simply ignore this and use TMDB ordering however they only have data for Seasons 1 & 2.
Any help/suggestions would be appreciated; thank you.
Then select something else temporarily.
Save, refresh metadata, then change it back.
Have you tried refreshing the metadata of the show, and then verify the episode order again?
As for the difference to TMDb: based on a 1st look, TMDb‘s seasons 1+2 seem to correspond with TheTVDb‘s Season 5+6. not sure if they have seasons 1-4 listed as a separate show [edit: yes, they do: Faster with Finnegan (2020)]
Funny enough, I just tried that and now the TVDB entry is completely missing…
Yes it’s kind of an odd situation, it was 4 seasons with the original host and then the last two seasons were two different hosts. So it’s kind of the same show. I guess if worse comes to worse i can try and split it as two shows I was really just hoping to be able to keep it as one show with 6 seasons as the TVDB entry has.
