iTVonline plugin
problem with sending request after streams started
hey guy's
i am currently working on a plugin for [http://www.itvonline.nl/](http://www.itvonline.nl/)
this is a website where constumers of the dutch company KPN can watch live TV
but i came across a problem. the website doesn't use different url for different channels
insteat a url request sent in the background when you try to change the channel
the server will than start streaming a different channel. so the actual site doesn't change
i already know al the parms to sent but u can only sent the request if the site is loaded
i use site config because te stream is encrypted
the site uses silverlight
so the trick is to have a function that launches after the site is loaded (and the stream plays) to sent the request
(if the users want to see a different channel than the defealt)
also because it is so easy to change the channel (you don't have to provide a new videoclibobject)
i would like some sort of a small box which popups on the users command to select a different channel
is this possible? it would by fantasitic to do make some sort af a carousel/scrollbar for this
(but i'm afriad this is impossible)
i already got the base code working so if i start the plugin it and i navigate to live TV
it will start playing the defealt channel (nederland 1)
(also is it a problem for plex that this steam is endless?)
Thanks!!
(P.S this is my for plugin for plex)
Loek
Sorry for my bad english i was never a star in it :(
little sniffing and we get next output, think you can possibly use it for fixing your app (note that itvonline is Silverlight based)
Ned1 = http://iis.phqstreamer21.kpnstreaming.nl/live/pkpnedge/Nederland1.isml/QualityLevels(384000)/FragmentInfo(video=35947216400000)
Ned2 = http://iis.phqstreamer18.kpnstreaming.nl/live/pkpnedge/Nederland2.isml/QualityLevels(128000)/Fragments(audio101=35949115988750)
Ned3 = http://iis.phqstreamer21.kpnstreaming.nl/live/pkpnedge/Nederland3.isml/QualityLevels(1200000)/Fragments(video=35949072000000)
RTL4 = http://iis.phqstreamer06.kpnstreaming.nl/live/pkpnedge/RTL4.isml/QualityLevels(128000)/FragmentInfo(audio101=35949997109166)
RTL5 = http://iis.phqstreamer19.kpnstreaming.nl/live/pkpnedge/RTL5.isml/QualityLevels(128000)/Fragments(audio101=31315579509166)
SBS6 = http://iis.phqstreamer04.kpnstreaming.nl/live/pkpnedge/SBS6.isml/QualityLevels(128000)/Fragments(audio101=31317213737083)
RTL7 = http://iis.phqstreamer19.kpnstreaming.nl/live/pkpnedge/RTL7.isml/QualityLevels(1200000)/Fragments(video=31317730400000)
NET5 = http://iis.phqstreamer21.kpnstreaming.nl/live/pkpnedge/NET5.isml/QualityLevels(1200000)/Fragments(video=31309094000000)
Veronica/Disney = http://iis.phqstreamer06.kpnstreaming.nl/live/pkpnedge/VeronicaDisneyXD.isml/QualityLevels(128000)/Fragments(audio101=31309583909166)
RTL8 = http://iis.phqstreamer20.kpnstreaming.nl/live/pkpnedge/RTL8.isml/QualityLevels(128000)/Fragments(audio101=31319013909166)
Comedy Central/Kindernet = http://iis.phqstreamer18.kpnstreaming.nl/live/pkpnedge/Kindernet.isml/QualityLevels(384000)/FragmentInfo(video=30037346000000)
Nickelodeon = http://iis.phqstreamer07.kpnstreaming.nl/live/pkpnedge/Nickelodeon.isml/QualityLevels(384000)/FragmentInfo(video=40933049600000)
MTV = http://iis.phqstreamer06.kpnstreaming.nl/live/pkpnedge/MTV.isml/QualityLevels(1200000)/Fragments(video=31250668400000)
Videotheek = http://iis.phqstreamer07.kpnstreaming.nl/live/pkpnedge/VideotheekTV.isml/QualityLevels(128000)/Fragments(audio101=31311029909166)
Discovery Channel = http://iis.phqstreamer05.kpnstreaming.nl/live/pkpnedge/DiscoveryChannel.isml/QualityLevels(128000)/FragmentInfo(audio101=22124262309166)
National Geographic = http://iis.phqstreamer18.kpnstreaming.nl/live/pkpnedge/NationalGeographic.isml/QualityLevels(1200000)/Fragments(video=22149408400000)
TLC = http://iis.phqstreamer07.kpnstreaming.nl/live/pkpnedge/AnimalPlanet.isml/QualityLevels(128000)/FragmentInfo(audio101=30038835109166)
24Kitchen = http://iis.phqstreamer04.kpnstreaming.nl/live/pkpnedge/24Kitchen.isml/QualityLevels(128000)/FragmentInfo(audio101=30014237509166)
BBC1 = http://iis.phqstreamer18.kpnstreaming.nl/live/pkpnedge/BBC1.isml/QualityLevels(128000)/FragmentInfo(audio101=31289975109166)
BBC2 = http://iis.phqstreamer20.kpnstreaming.nl/live/pkpnedge/BBC2.isml/QualityLevels(128000)/Fragments(audio101=22146087109166)
BBC3 = http://iis.phqstreamer21.kpnstreaming.nl/live/pkpnedge/BBCThree.isml/QualityLevels(128000)/Fragments(audio101=40852417215000)
BBC4 = http://iis.phqstreamer06.kpnstreaming.nl/live/pkpnedge/BBCFour.isml/QualityLevels(128000)/FragmentInfo(audio101=40853011946250)
één = http://iis.phqstreamer07.kpnstreaming.nl/live/pkpnedge/EEN.isml/QualityLevels(128000)/Fragments(audio101=31265622309166)
Canvas = http://iis.phqstreamer06.kpnstreaming.nl/live/pkpnedge/Canvas.isml/QualityLevels(128000)/Fragments(audio101=31265365909166)
Ketnet = http://iis.phqstreamer05.kpnstreaming.nl/live/pkpnedge/Ketnet.isml/QualityLevels(128000)/FragmentInfo(audio101=31249312915000)
Eurosport = http://iis.phqstreamer05.kpnstreaming.nl/live/pkpnedge/Eurosport.isml/QualityLevels(128000)/FragmentInfo(audio101=29925446174166)
Humor TV 24 = http://iis.phqstreamer04.kpnstreaming.nl/live/pkpnedge/HumorTV24.isml/QualityLevels(128000)/FragmentInfo(audio101=22152794709166)
NOS Journaal 24 = http://iis.phqstreamer19.kpnstreaming.nl/live/pkpnedge/NOSJournaal24.isml/QualityLevels(128000)/Fragments(audio101=31292006309166)
13th Street = http://iis.phqstreamer21.kpnstreaming.nl/live/pkpnedge/13thStreet.isml/QualityLevels(128000)/FragmentInfo(audio101=22153270538333)
CNN = http://iis.phqstreamer07.kpnstreaming.nl/live/pkpnedge/CNN.isml/QualityLevels(128000)/FragmentInfo(audio101=22153223509166)
BBC World News = http://iis.phqstreamer20.kpnstreaming.nl/live/pkpnedge/BBCWorldNews.isml/QualityLevels(128000)/FragmentInfo(audio101=31293195909166)
Xite = http://iis.phqstreamer18.kpnstreaming.nl/live/pkpnedge/Xite.isml/QualityLevels(128000)/Fragments(audio101=40924083509166)
Nick Jr = http://iis.phqstreamer19.kpnstreaming.nl/live/pkpnedge/NickJr.isml/QualityLevels(128000)/FragmentInfo(audio101=19961059509166)
Baby TV = http://iis.phqstreamer20.kpnstreaming.nl/live/pkpnedge/BabyTV.isml/QualityLevels(128000)/FragmentInfo(audio101=19960609793333)
TV5 MONDE = http://iis.phqstreamer21.kpnstreaming.nl/live/pkpnedge/TV5.isml/QualityLevels(128000)/Fragments(audio101=31295232601666)
Politiek 24 = http://iis.phqstreamer06.kpnstreaming.nl/live/pkpnedge/Politiek24.isml/QualityLevels(384000)/FragmentInfo(video=19963201200000)
Holland Doc 24 = http://iis.phqstreamer07.kpnstreaming.nl/live/pkpnedge/HollandDoc24.isml/QualityLevels(1200000)/Fragments(video=19967872400000)
History = http://iis.phqstreamer04.kpnstreaming.nl/live/pkpnedge/History.isml/QualityLevels(384000)/FragmentInfo(video=19968130400000)
Discovery Science = http://iis.phqstreamer19.kpnstreaming.nl/live/pkpnedge/DiscoveryScience.isml/QualityLevels(128000)/Fragments(audio101=19968319113750)
Discovery World = http://iis.phqstreamer06.kpnstreaming.nl/live/pkpnedge/DiscoveryWorld.isml/QualityLevels(128000)/FragmentInfo(audio101=19968759912916)
Animal Planet = http://iis.phqstreamer07.kpnstreaming.nl/live/pkpnedge/AnimalPlanet2.isml/QualityLevels(128000)/FragmentInfo(audio101=19980197509583)
Travel Channel = http://iis.phqstreamer04.kpnstreaming.nl/live/pkpnedge/TravelChannel.isml/QualityLevels(128000)/Fragments(audio101=19980140850833)
Nat Geo Wild = http://iis.phqstreamer05.kpnstreaming.nl/live/pkpnedge/NatGeoWild.isml/QualityLevels(128000)/FragmentInfo(audio101=19980625016250)
Eurosport 2 = http://iis.phqstreamer20.kpnstreaming.nl/live/pkpnedge/Eurosport2.isml/QualityLevels(128000)/Fragments(audio101=19980344069166)
Motors TV = http://iis.phqstreamer07.kpnstreaming.nl/live/pkpnedge/MotorsTV.isml/QualityLevels(1200000)/Fragments(video=19345390800000)
Best 24 = http://iis.phqstreamer07.kpnstreaming.nl/live/pkpnedge/Best24.isml/QualityLevels(384000)/FragmentInfo(video=19954892800000)
TNT = http://iis.phqstreamer06.kpnstreaming.nl/live/pkpnedge/TNT.isml/QualityLevels(128000)/FragmentInfo(audio101=19955141509166)
Comedy Central Extra = http://iis.phqstreamer19.kpnstreaming.nl/live/pkpnedge/ComedyCentralExtra.isml/QualityLevels(128000)/Fragments(audio101=19968791669583)
Comedy Central Family = http://iis.phqstreamer04.kpnstreaming.nl/live/pkpnedge/ComedyCentralFamily.isml/QualityLevels(1200000)/Fragments(video=19969086400000)
101 TV = http://iis.phqstreamer07.kpnstreaming.nl/live/pkpnedge/101TV.isml/QualityLevels(384000)/Fragments(video=19969523600000)
The Player Channel = http://iis.phqstreamer04.kpnstreaming.nl/live/pkpnedge/ThePlayerChannel.isml/QualityLevels(128000)/FragmentInfo(audio101=19970108309166)
VH1 = http://iis.phqstreamer05.kpnstreaming.nl/live/pkpnedge/VH1.isml/QualityLevels(128000)/FragmentInfo(audio101=19970639909166)
MTV Music24 = http://iis.phqstreamer18.kpnstreaming.nl/live/pkpnedge/MTVMusic24.isml/QualityLevels(128000)/FragmentInfo(audio101=19970847909166)
SLAM! TV = http://iis.phqstreamer06.kpnstreaming.nl/live/pkpnedge/SlamTV.isml/QualityLevels(128000)/FragmentInfo(audio101=31324739109166)
Djazz TV = http://iis.phqstreamer07.kpnstreaming.nl/live/pkpnedge/Djazztv.isml/QualityLevels(128000)/FragmentInfo(audio101=19967557416666)
TV Oranje = http://iis.phqstreamer18.kpnstreaming.nl/live/pkpnedge/TVOranje.isml/QualityLevels(128000)/FragmentInfo(audio101=19969711022083)
192 TV = http://iis.phqstreamer18.kpnstreaming.nl/live/pkpnedge/192TV.isml/QualityLevels(128000)/Fragments(audio101=19971359818750)
Trace TV = http://iis.phqstreamer07.kpnstreaming.nl/live/pkpnedge/TraceTV.isml/QualityLevels(128000)/FragmentInfo(audio101=19971217462500)
Inform me when ready
MUST HAVE !!
Used software - URLSnooper 2.32.01
Regards, Patrick
Your best chance would be to get Sander1 to have a look.
Since you are in the Netherlands ,the other option would be to get a subscription with XS4ALL.  :D
http://forums.plexapp.com/index.php/topic/66954-channel-xs4all-webtv/
Jerry
The links above won’t work because they point to fragments of a smooth stream (http://www.iis.net/media/experiencesmoothstreaming )
A solution may be to use the steam the iphone app uses but i haven’t look in to this ( don’t expect much because the iphone app takes a long time to start up this is most likely authenticating)
