Just Switched - 30 Second Skip - Slow?
Was using normal PHT until yesterday because up in till I upgraded the latest Media Server is still was solid enough for me, but now that Plex broke the mark watched after playback it forced me to look into PMP again. And the same issues I had with PMP before not being as customizable it being much slower and so forth I decided to look in the Forums, because i could not stay with PMP.
I am so glad the OPEN PHT team and contributes are building this and taking up the mantel of the old PHT, I was going to look into the Kodi plugin versions but this seems to fit the bill very well. Many improvements from the last old version of PHT I was using, and i love the Black Theme. So thanks again everyone working on this project.
I do have 1 slight bug that someone on here might be able to help me out with, the old PHT when i did the 30 second skip forward or 15 second skip back it was perfect and extremely fast resuming playback with hardly any pause at all. Where in the current version of Open-PHT there is a noticeable 1-3 second lag after jumping to that point in the video.
Is there any way to get it to work like it did back in the last version of PHT? I have already put the cache to the 30% max cache, But i dont think that has anything to do with it because the old pht is at the default 5% and works flawlessly.
Please point me in the right direction and i can stumble around and trial and error- thanks in advance.
DOH - Found it myself, but will keep it on here if it will help anyone else out. I dont know why someone would want a skip delay of 750 ms, but just took a little digging and found out how to turn it off.
Navigate to Preferences - Screen - Advanced Video
Change Skip Delay from default 750 ms to None.
Thats it, working much better for me.
OpenPHT now uses adaptive seeking, you can vary the default amount to suit your own personal tastes, doing what you have done brings back the ‘old’ way of ‘jumping’. There also a similar setting in Music preferences.
Regards
