Justin.tv Plugin
Initial Release
Hi folks,
After the brilliant [plugin wizard tool](http://dev.plexapp.com/tools/plugin_kickstart/) was announced I decided to take a crack another plugin.
I use Justin.tv all the time for sports and other miscellaneous entertainment so I made a Plex plugin for it.
Details are available at the [wiki page](http://wiki.plexapp.com/index.php/Justin.tv) and the bundle is attached to this post.
Please give it a try and let me know how it works. There are a few things posted in the known issues section on the wiki but I thought I'd release it now since it mostly works.
If anyone has interest or skills, it'd be great to come up with some better icons and backdrop graphics/artwork.
Anyway hope you enjoy and let me know how it's working.
Nice! Did you end up using the Justin.tv API or just screen scraping. Glad the wizard was of use ;)
Little bit of both. I use the API to get the stream listings, descriptions, screenshots but I couldn't get a direct link to an FLV from the API, only a compressed SWF which Plex complained about. Uses site configuration for playback (for now).
In case anyone still wants to help, here are the resources I used for the graphics and a few extras I didn’t use.
http://www.box.net/shared/laq1c7e7di
A graphic for each category would be a nice touch as well.
Hi, I really want to watch the 24 ATHF HD channel, but I can’t log in to justin.tv from the app. When I go to the website it requires my login to prove I’m of age. THank you for the work you have put into this app. justin.tv is so needed in a media center.
This doesn’t work for me.
Any video that I try, I only get sound and a Image like the attached. Any thoughts?
http://feit.nu/plex.jpg
this has nothing to do with this plugin. please check the top thread in the media plugin forum.
(this one)
Any way to get rid of the Ads by Google?
I would love this plugin with just a few tweeks
-login so that you can see a list of streams you follow.
-the google ads gone.
-bottom menu bar gone so it doesn’t burn on to my plasma
any chance of the OP coming back to change the code?
Not for a while, I've been busy lately, and since having Cable TV again, I haven't really needed JTV. Just watch the thread, I might take a look at enhancing it, but even better, someone else could take the code and improve it!
thanks for replying so quick! I might try and look at the code, but this really isn’t my kind of thing!
New Plugin available here:
http://forums.plexapp.com/index.php/topic/26120-updated-plugin-justintv/
