Thanks @marcelopazzo, this answers my original question regarding the need for a legacy Plex token.
However, I am unable to get the Plex JWT from the last step.
After the user signs in to the Plex login page (from the auth url), I query the pin endpoint with my signed device JWT, but there is no Plex JWT in the response.
Did you get any error, or just a plain legacy token in the authToken field? If any fields are missing in the device JWT provided, the endpoint should return an error message with the details.
I kept getting a legacy token in the authToken field.
After more fiddling around, I think I found the problem. The pin endpoint
GET https://clients.plex.tv/api/v2/pins/<pinID>?deviceJWT=<signedJWT>
does not work with a JSON response. As soon as I remove the Accept: application/json header and use the XML response it is working and I get the Plex JWT in the authToken field.
Second question, does this Plex JWT authentication method work with the 4 digit code method used at https://plex.tv/link (i.e. without strong=true) instead of using the auth URL?
Sorry for the delay in getting back to you, but with a 4-digit code, you will need to use the http://plex.tv/link interface instead of the /auth page. Is there any scenario where we need to use a short pin on the /auth interface?
I think everything is actually working properly. Both XML and JSON and both OAuth or 4-digit code.
I needed to generate a completely new client identifier and keypair to properly do a clean test of each method. Trying to reuse the same client identifier or keypair when swapping between XML and JSON or between OAuth and 4-digit code causes issues.
Any plans to actually implement API level keys? similar to how other platforms do it? for example, currently in WatchState which is a tool that allow plex server owner to sync their user play state rely on admin token to generate sub tokens for users which has access to plex server.
Ideally, there will be API keys that could be used with tools and users are identified by their IDs and their data accessed that way.
Plex currently has:
1- main user
2- home users
3- users whom have access to the server
generating keys and tokens and trying to keep all of those in sync is rather difficult. Also,
Also i am not sure if this is the case, but users who has access to the server who aren’t home users, are supposed to be different account yeah? if so isn’t uploading pubkey to their account kind expose them to more security issues?
currently tokens are tied to the server not an account afaik
1- is the old auth system going to be removed or are we able to use it and ignore JWT?
2- Can we have more endpoints that supports this JWT system? currently during my testing for full implementation i have run into many issues.
There is no way to know if a clientid/pubkey is already enrolled except an error message during enrollment. Which also has problems as its checks the clientid only not the pubkey.
No endpoint to remove old key, use case a user removed the keys by mistake etc he cant re-enroll automatically even deleting the client from the account still references the old pubkey.
Its not explained how to handle multi-user setup with the new auth system.
lets say we enroll the main admin user account does that mean the key know has access to generate auth requests for all home/users and all the people who has been invited to the server? or do we have to generate enrollment for each?
If we have to enroll all of servers sub users can we use same privkey/pubkey or we need to generate for each?
Honestly all of these issues would have been avoided if you provided server API keys like the rest of the industry using this multitiered auth system is confusing when you have many factors to consider a user account here could mean 1 user or all home users or users who has access to a server.
There are so many unknowns i hope that you dont shutdown the old authentication system until all these issues has been worked out.
