Keep settings and meta data with different mapping
Server Version#: 1.14.1.5488
Here’s the use case: I’m running Plex on a Windows machine, but all of the media is currently residing on a NAS. I’m planning to rebuild the NAS, and during that process, I may need to change the UNC path to the media. However, the media structure will remain the same. Is there a way to update the root UNC path, without losing all of the metadata? I have a Plex pass, if it matters.
Thanks.
Only this: [HowTo] Plex database modification - Moving media the right/wrong way
But you should be able to keep the UNC path stable since you can freely change the machine name, share names and folder names of your NAS.
I recommend you to completely close/quit/shutdown Plex during all of this.
