Keeps looking for server
Thanks. I set up a bond between the two NICs and reinstalled Plex MS. Still no luck. The MTU is already auto and firewall is allowing traffic.
After configuring the bond I no longer see the Plex drive in the DSM File Station or even listed under Volumes on my Mac shell. I’m not sure where it is running from.
Yes I installed the latest PMS from plex.tv and installed it on DSM. I can see it is running in DSM, just can’t see the file system like I was able to be before the NIC bond (auto load balancing).
By auto i meant I have not ticked (enabled) the manual mtu setting.
Plex.tv is not displaying correctly. Keeps looking for servers.
Are these the right websites for these pings?
And are they supposed to go to totally different site hosting?
C:>ping forums.plex.tv
Pinging plex.hosted-by-discourse.com [64.71.168.222] with 32 bytes of data:
Reply from 64.71.168.222: bytes=32 time=91ms TTL=48
Reply from 64.71.168.222: bytes=32 time=92ms TTL=48
Reply from 64.71.168.222: bytes=32 time=94ms TTL=48
Ping statistics for 64.71.168.222:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 91ms, Maximum = 94ms, Average = 92ms
C:>ping www.plex.tv
Pinging cluster95-elbwpeel-1rcyft0q3nddc-1014054933.us-east-1.elb.amazonaws.com [34.202.207.128] with 32 bytes of data:
Reply from 34.202.207.128: bytes=32 time=38ms TTL=236
Reply from 34.202.207.128: bytes=32 time=37ms TTL=236
Reply from 34.202.207.128: bytes=32 time=39ms TTL=236
Reply from 34.202.207.128: bytes=32 time=40ms TTL=236
Ping statistics for 34.202.207.128:
Minimum = 37ms, Maximum = 40ms, Average = 38ms
Removing “Preferences.xml” and going to :32400/web made the trick… thanks @trumpy81 !!
