Hello,
I am looking towards buying a NAS device and use it both as a server and storage. In order to do that, I read all the different articles in the FAQ and checked out the Compatibility List. Since I am not very knowledgeable on the topic, I would kindly appreciate validation on my thought process from those who understand about this topic more than I do.
After reading the articles, I am able to determine the following:
- NAS device to be used both for server and storage (at least 12 TB).
- Transcoding will be required, for 1080p files, subtitles, as well as for several types of devices (Samsung TV, Android phone and tablet) and users (unlikely at the same time though).
- The format of my media is always “standard”, they are listed as examples in Is Plex Media Server on a NAS Right for Me?.
- Based on the above info, I filtered the NAS Compatibility List based on the following criteria:
a) x86 CPU;
b) HD 1080p = Yes;
c) checked out the CPU PassMark of a few models (which very roughly should be around 2000 for a single full transcode of a video 1080p as per the FAQ).
Based on the above, PRICE is the driving factor in order to acquire a NAS device. The cheapest one I have been able to find fulfilling the above requirements is the model
Western Digital MyCloud Pro PR2100.
However, its CPU PassMark (1886) falls below the suggested 2000 bar, and its 1.6GHz processor is also lower than the basic minimum suggestion (2.4 GHz); which I assume it indicates low power (?).
My questions to those who are more knowledgeable on this topic than me are:
- Did I go about this more or less correctly, or am I overlooking anything?
- Is this choice still correct in spite of the CPU characteristics (I am confused about the supposed sub-optimum CPU details as per above, but yet showing as a result when filtering the Compatibility List; which one is it?).
- What would be a cheap alternative which would fit my needs?
Once again, I highly appreciate any kind assistance anyone may provide on this matter. Thanks, best regards,
), which leads me to believe that the proposals may be a bit over my head.
