When I’m looking at tv shows within a season. I have an issue with the kinect voice select. Example, if there is 8 episode in a season. The kinect voice select will only give you options for 6 of the 8 episodes. Not sure if anyone else has seen this issue
You should have the option for 'Next Page' to get the last two items. I haven't tested it with a season with only 8 episodes, but on my normal seasons it works that only the first six episodes are selectable.
Occasionally when going between plex and other apps/games I will get into the app and not have an option for next page but doing go back and reselecting the season usually fixes it for me.
Sadly there is no 'Next Page' option with only 8 episodes. If there was a 9th episode, the 'Next Page' option shows up. I haven't check to see if this happens with 7 episodes but I would assume this issue would happen with that also.
I also notice im not able to use the hand gesture to grab and scroll through. Not sure if anyone is having this issue. I haven't look through the forums for that specific issue yet but I'll see if that topic has already started.
I am having this same issue, for instance i have a show that has 12 episodes, the last page shows episodes 5 through 12 but when I do the select command episodes 11 and 12 at the end do not have select commands and I cannot do next page to get to them. This has happened on other shows as well and when the issue occurs its only on the last two episodes on the far right, normally you do a next page in these cases but it just doesnt work at the end for those last two.
I am having the exact issue. Always in TV Shows and always with the Odd Number. Voice Command doesn't recognize the next page, I'm assuming because the are displayed. You have to either hand scroll, which doesn't always work, or worse break out the remote and manually click over.
This seems like it should be a pretty simple fix, the question is whether it's a Plex issue, or an Xbox One issue.
I have same problem. See here. https://forums.plex.tv/topic/167514-plex-not-selecting-all-boxes/#entry955804
Looks like the latest update fix the issue I was seeing in this thread.
