Loving the app - a few small bugs and suggestions
Hey guys,
Loving the debut app, shows amazing promise!
My stuff is with some of the voice and gesture sides of things, from time to time when navigating to a new page, the "previous page" and "next page commands" don't come across so you have to get the xbox to "stop listening" and then get it to start again, its just a little time consuming.
Occasionally when you browse via voice into a TV show and then "go back" the main alphabetical program list, the list is muddled up and the voice index doesn't work (ie saying "select 13" doesn't work but makes the selection sound).
Gesture stuff
One thing with the gesture control is that when you hover your hand over an episode, I would love to see it come up with the episode name like you can when using the controller.
Can you make the play button a little bigger and a little more separate from the other buttons? It is quite hard to get your hand to navigate onto that.
I've said in another post, that I really am loving this app, just a few suggestions!
^ I second this. ^
Also the show/movie detail page get muddled if you have something snapped to Plex (not Plex snapped, but something snapped to the side of Plex).  Probably something you didn't have time to test.
There is also this weird bug where the green words for voice (Go back, etc) persists after coming back from watching a video and actually are duplicated.  Might have something to do with using voice to "play" something (Green words will show up) and then using voice to "stop" (second instance of the green words show up once back from the video.. they draw a bit off position from the previous words). I hope that makes sense.
