Lagging and buffering
Followup. It will transcode the TrueHD if the player can’t accept it (most don’t). TrueHD -> AAC or AC3 can put an appreciable load on a smaller NAS (up to 30%)
apologies for not stating this earlier.
Well, all the metadata were retrieved for some time now, and the TrueHD track was only on the movie I was talking about. I just watched an 1080p episode, in direct play (video+audio), the cpu/ram load is quite low but it’s still stuttering whereas I can see that there’s buffer ahead on the progression bar.
If you have buffering in a DirectPlay situation, You have app or network issues.
DirectPlay takes about 3-4% of an i7 processor (7-10% of a typical NAS processor) in the worst of cases.
Are you using WiFi? Is it 2.4 Ghz (cluttered) or 5 Ghz through a few walls (low signal strength) ?
That’s what I thought, DirectPlay should be smooth with a DS918+.
No, my TV is connected to my modem through a RJ45 cable. I’m investigating this connection since I run a speedtest and the bandwith is ~90Mbps, which is just about what I have with Wifi 2.4GHz (from my NAS it tops at 800Mbps), so I guess there’s something wrong.
Modems are strange animals.
While they have a switch inside them (the multi-port capability), it’s not their purpose and cross-port communication (switching) isn’t the specialty. It’s a modem-router
To add, most televisions are only good for 100 Mbps. so speed tests which show 800 Mbps don’t have merit unless you are running the speedtest at the television itself (e.g. attached AppleTV 4K which is wired with Gigabit).
I concur that something is wrong. the challenge is finding where the slow spot is.
Is it the television’s ability to receive or to reply / ask for more data ?
Is it the LAN itself? The LAN seems fine so we need to dig deeper.
In my LAN, My modem/router (pfSense) feeds the main switches (HPE-1820-24G & GS110/EMX). All traffic goes through those switches.
Even though it’s a 10 GbE switch, with 5 GbE adapter on the computer,
[chuck@telfs ~.90]$ iperf3 -c 192.168.0.21
Connecting to host 192.168.0.21, port 5201
[  5] local 192.168.0.13 port 59022 connected to 192.168.0.21 port 5201
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.00   sec   378 MBytes  3.17 Gbits/sec    0   4.00 MBytes
[  5]   1.00-2.00   sec   374 MBytes  3.14 Gbits/sec    0   4.00 MBytes
[  5]   2.00-3.00   sec   375 MBytes  3.15 Gbits/sec    0   4.00 MBytes
[  5]   3.00-4.00   sec   376 MBytes  3.16 Gbits/sec    0   4.00 MBytes
[  5]   4.00-5.00   sec   378 MBytes  3.17 Gbits/sec    0   4.00 MBytes
[  5]   5.00-6.00   sec   376 MBytes  3.16 Gbits/sec    0   4.00 MBytes
[  5]   6.00-7.00   sec   378 MBytes  3.17 Gbits/sec    0   4.00 MBytes
[  5]   7.00-8.00   sec   378 MBytes  3.17 Gbits/sec    0   4.00 MBytes
[  5]   8.00-9.00   sec   374 MBytes  3.14 Gbits/sec    0   4.00 MBytes
[  5]   9.00-10.00  sec   378 MBytes  3.17 Gbits/sec    0   4.00 MBytes
[  5]   0.00-10.00  sec  3.67 GBytes  3.16 Gbits/sec    0             sender
[  5]   0.00-10.00  sec  3.67 GBytes  3.16 Gbits/sec                  receiver
iperf Done.
[chuck@telfs ~.91]$ iperf3 -c 192.168.0.21 -R
Reverse mode, remote host 192.168.0.21 is sending
[  5] local 192.168.0.13 port 59026 connected to 192.168.0.21 port 5201
[  5]   0.00-1.00   sec   352 MBytes  2.96 Gbits/sec
[  5]   1.00-2.00   sec   363 MBytes  3.04 Gbits/sec
[  5]   2.00-3.00   sec   361 MBytes  3.03 Gbits/sec
[  5]   3.00-4.00   sec   364 MBytes  3.05 Gbits/sec
[  5]   4.00-5.00   sec   342 MBytes  2.87 Gbits/sec
[  5]   5.00-6.00   sec   364 MBytes  3.06 Gbits/sec
[  5]   6.00-7.00   sec   344 MBytes  2.89 Gbits/sec
[  5]   7.00-8.00   sec   361 MBytes  3.02 Gbits/sec
[  5]   8.00-9.00   sec   331 MBytes  2.78 Gbits/sec
[  5]   9.00-10.00  sec   363 MBytes  3.04 Gbits/sec
[  5]   0.00-10.00  sec  3.47 GBytes  2.98 Gbits/sec  10949             sender
[  5]   0.00-10.00  sec  3.46 GBytes  2.97 Gbits/sec                  receiver
iperf Done.
[chuck@telfs ~.92]$ ```
Well I have bad news. I tried emby and the playback is smooth, no stuttering :confused:
I don’t have stuttering even on a single 1 Gb link.
To complicate matters, I’ve upgraded my host and now have a NUC HadesCanyon with 10 Gbps
[  5] local 192.168.0.13 port 51750 connected to 192.168.0.21 port 5201
[  5]   0.00-1.00   sec  1.09 GBytes  9.40 Gbits/sec    0   1.57 MBytes
[  5]   1.00-2.00   sec  1.10 GBytes  9.42 Gbits/sec    0   1.57 MBytes
[  5]   2.00-3.00   sec  1.10 GBytes  9.42 Gbits/sec    0   1.65 MBytes
[  5]   3.00-4.00   sec  1.09 GBytes  9.41 Gbits/sec    0   1.65 MBytes
[  5]   4.00-5.00   sec  1.10 GBytes  9.42 Gbits/sec    0   1.86 MBytes
[  5]   5.00-6.00   sec  1.09 GBytes  9.38 Gbits/sec    0   1.86 MBytes
[  5]   6.00-7.00   sec  1.09 GBytes  9.41 Gbits/sec    0   1.86 MBytes
[  5]   7.00-8.00   sec  1.10 GBytes  9.42 Gbits/sec    0   1.86 MBytes
[  5]   8.00-9.00   sec  1.10 GBytes  9.42 Gbits/sec    0   1.86 MBytes
[  5]   9.00-10.00  sec  1.09 GBytes  9.41 Gbits/sec    0   1.96 MBytes
[  5]   0.00-10.00  sec  11.0 GBytes  9.41 Gbits/sec    0             sender
[  5]   0.00-10.00  sec  11.0 GBytes  9.41 Gbits/sec                  receiver
iperf Done.
[chuck@lizum plex-media-server.198]$ iperf3 -c 192.168.0.21 -R
[  5] local 192.168.0.13 port 51758 connected to 192.168.0.21 port 5201
[  5]   0.00-1.00   sec  1.09 GBytes  9.38 Gbits/sec
[  5]   1.00-2.00   sec  1.10 GBytes  9.41 Gbits/sec
[  5]   2.00-3.00   sec  1.10 GBytes  9.41 Gbits/sec
[  5]   3.00-4.00   sec  1.10 GBytes  9.42 Gbits/sec
[  5]   4.00-5.00   sec  1.10 GBytes  9.41 Gbits/sec
[  5]   5.00-6.00   sec  1.10 GBytes  9.41 Gbits/sec
[  5]   6.00-7.00   sec  1.10 GBytes  9.41 Gbits/sec
[  5]   7.00-8.00   sec  1.10 GBytes  9.41 Gbits/sec
[  5]   8.00-9.00   sec  1.10 GBytes  9.41 Gbits/sec
[  5]   9.00-10.00  sec  1.10 GBytes  9.42 Gbits/sec
[  5]   0.00-10.00  sec  11.0 GBytes  9.42 Gbits/sec    0             sender
iperf Done.
[chuck@lizum plex-media-server.199]$ ```
I will now start profiling processor load to see what I can find.   I know I'm missing something.   I'm sorry for overlooking whatever I am.   Health has been interfering of recent.
Wow 10Gbps :smiley:
Good news, I deleted my movie and tv show librairies and created them again. Stuttering seems to have gone away since then!
Hi Chuck,
Do you know/think the hardware acceleration for burning subtitles will be included in the VA-API soon?
I’m currently also running PMS on a Celeron J3455 and while most streams work just fine with transcoding, adding subtitles to a Blu-ray rip will cause constant buffering.
Was looking at pricing for the newest NUCs earlier today, but I’d rather save the money or buy some movies instead.
I have no idea when hardware support for burning subtitles will be added.
IMHO, it’s one of the first things that should have been added but :man_shrugging: I’m just a lowly engineer.
The J3455 has a regular GPU in addition to the video ASIC.
To my mind, tasking the GPU to render the subtitle font is trivial. Text on a graphics display is how it’s done . Using the ASIC to merge that bitmap plane onto the video plane is another logical “OR” (merge) operation.
