LAN Networks - IPv6
I entered my v6 /48 under ‘LAN Networks’ along with my v4 /24 & /12. When clients play from the v4 networks they show as ‘local’ however when client play from the v6 /48 they are classified as remote.
Is this setting supposed to support IPv6?
Server Version#: 1.31.3.6868
Player Version#: 1.66.1.3632-4d9c7716
It’s supposed to work for IPv6 but doesn’t.
The issue has been written up and submitted to Engineering.
I’ll see if I can get some traction on it.
Are you in an IPv6-only WAN ISP as well?
Okay, thanks for that. My ISP provides me with one v4 address and delegates a /48 of v6 space, which I make use of.
With ISPs handing out /48s to everyone, at current rate I expect IPv6 to run out really fast too. It won’t take long to really make a mess. How many of us need 65536 networks in our home? :slight_smile:
That’s how it should be, one /48 per curstomer is the IETF recommendation (RFC6177), although in practice that’s mostly typical for Pro connections, a /56 is also allowed and most prevalent among residential ISPs.
Even with /48 allocations we’re not running out of space anytime soon - within the current 2000::/3 public space, we can issue over 35,000,000,000,000 of them.
If I’m not mistaken, Plex can handle IPv6 or IPv4 subnets in that “LAN networks” box, but not a combination of both, can you confirm @ChuckPa ?
PMS should handle either and both (dual stack networks / machines) but there’s a bug which I brought up in today’s meeting. (There’s an open bug submitted for this - #14234)
Upon review, the code currently in place only supports IPv4 (32 bit) and the parser itself doesn’t support IPv6 addressing formats.
The work to do that is now scheduled. I don’t know when it will be released as there are some other higher priority tasks to complete first.
