Language selection greyed out on dvr setup
Capture
setting up my live tv after the crap that was the broken update. now the language selection continue button is greyed out no matter what i choose. i have tried shut down restart reinstall repair, nothing works
any help would be appreciated
Well, when it’s on “Select Language” I expect this behavior, but you’re saying even if you choose english, or some other language, the continue button is still unclickable?
yes it is still unclickable
Yeah, I got nothin… That’s definitely a problem… and it’s not one I think you can even provide logs for… Hopefully someone here will be able to help…
You may as well provide all of your info though, someone is definitely going to need it and ask for that.
Operating System
Plex Server Version
Location (Country is all that is necessary (May be helpful with EPG stuff))
Maybe Server Hardware Specs…
Capture Device Being used
just a heads up, i downloaded a xmltv from a free website and i was able to progress but i dont have all my local channels and it took alot of manual config, it seems plex is unable to retrieve the tv guide.
os: windows 10
plex server version: 1.18.2.2015
capture device: HDhomerun
This is probably what it is… When plex changed EPG providers they lost Australian EPG. There is something setup for this (I don’t think it’s free though).
Go here and look at the popular links section, seems to be quite a few:
I think this was the one that they brokered a deal with:
