DVR Setup in Australia not working
Hello,
I’m trying to set up my DVR after my SSD died and lost my Plex Server.
I get to the part of the DVR setup where I select Antenna and the Country. I cannot click next. It will not let me proceed to the next step. It tells me I need to scan. Obviously it’s going to fail the scan because I cannot select Australia from the list like I used to. I have purchased a subscription to IceTV for their EPG data, but I cannot get to the next step where I input their web address they sent me. My DVR is a WinTV DualHD.
I have the latest version of Plex Server (1.16.0.1226)
I have a lifetime Plex Pass.
Same issue here :frowning:
They really dropped the ball on this one.
If you use the public PMS version (1.15.8), you should be able to set up your DVR. We’re aware of this issue in the beta, and are investigating.
Any Update on this issue - I have run into the same problem
Can someone confirm if this is a bug or whether or not Plex has dropped support for EPG in Australia? Because if it’s the latter then the promise of being able to watch and record Live TV with my plex pass is a lie,because without the guide data I can’t (well I can on any other system, just not on plex in it’s infinte wisdom)…hence i will be requesting a refund and putting that money into other software
needs more salt in this thread /rolls eyes
http://freepg.tv/
free.. pump the url for your freepg account into the manual xmltv section.. and done.
put that.. into the section as per https://support.plex.tv/articles/using-an-xmltv-guide/
Hi DaveBinM,
Contrary to Robert’s July 4 post on the thread on IceTV forum (IceTV Forum - Index), when I tried on a Windows 10 computer to setup the Plex DVR with FreEPG.tv XML, it failed with the same symptoms as my Asustor NAS with the IceTV XML.
The common thread of both failures is version 1.16.1.1291 of the Plex Server.
As per icyTAZ on the IceTV Forum on July 3, I’m also reluctant to roll-back to 1.15.8, which you advised 17 days ago should not have this issue.
I’ll see if I can PM you the logs from the Win 10/freEPG.tv failure.
im running windows 10 and latest plex server builds. i have no issues with freepg.tv feed
Version 1.16.1.1291
Microsoft Windows [Version 10.0.17763.557]
EDIT: I did get a weird error, then i removed the tuner config, restarted the plex server and then re-added the tuner.
I am in Australia and am experiencing these same issues as a result of trying to correct the now loss of the Plex EPG, I am running Plex on Synology ver 1.16.2.1297-4b7ace214, and a HDHomerun Quatro tuner. I followed the Plex procedure that came in the email, and find the Tuner by adding in the IP address and finds it OK, then insert the URL for my iCETV EPG XMLTV, then the channels all show OK, but then when I hit continue it just spins and spins and never completes! same everyone is experiencing ! Is Plex working on this issue to come up with a fix ? soon?? Lifetime subscription to Plex !??
Are you also running the HDHomeRun Quatro tuner? I wonder if that is the common thread.
In Australia, running PMS Version 1.16.2.1297 on Win 10 with all updates. Ever since Monday (i think), I have lost my Hauppauge WinTV-quadHD TV Tuner from Plex. Works fine on PC within WinTV 8.5 player for all channels (Sydney). No issues for the past 7-8 months and bam! gone. Now I am not able to get Plex to install the tuner again.
I have reinstalled the WinTV 8.5 software and tuner drivers x2 times, shut down PMS and rebooted several times, but Plex will not recognise the tuner anymore. All other content is streaming fine. I accept, although very unhappy with the situation regarding the EPG being removed in Australia. However I should be able to setup the tuner and either use IceTV or another EPG provider. I’m currently on a yearly pass and was about the upgrade to the Lifetime pass. Not sure if thats a great idea now!
I have the same TV tuner. Same issue. It won’t detect. Was fine for a year until the EPG stuff got removed.
Nope. Public version has the same issue!
Apologies, I have now uninstalled latest version PMS and installed previous PMS version (1.15.8). I can now get tuner to be installed. However, of the 4x HD tuners I have only 2x HD are being recognised. Happy with that for now. Still not happy with all this palava though, especially since it’s a paid service!
I have exactly the same situation except my HDHomeRun is the duo - not Quatro.
1.15.8 has the same issue for you?
HI DaveBinM, How, where can I get a version of Plex for Synology that is prior to this latest version that has this bug!?? Really missing my DVR :frowning:
If you are looking for xmltv for Australia check this link [Link Removed]. Electronic program guide (EPG) data is subject to Australian copyright laws. We’ve been informed that the previously-linked XLMTV file contains information gathered in an unauthorized manner from another source. As such, it is in violation of those copyright laws and cannot be posted on this forum. Please do not post this link or source anywhere else on this forum.
Is this the hosted version of your scripts?
