Server Version#: Latest
Player Version#: Latest
I currently have a Synology DS918+ with a DX517-1 expansion cabinet filled with 9 10TB Western Digital Red hard drives. I just don’t like the potential for ruining a volume by combining all 9 into one volume. I guess I could if I had to. So, right now, I have two 30TB usable drives with the 5th drive in the expansion cabinet being reserved for a hot spare.
The problem is that I have so much content, I am running low on space. 78% on the first 30TB partition used and 90% on the second. So, it is time to start thinking about expanding.
I could go through and compress all my content but I really do not want to do that because of the amount of loss on a compressed file PLUS the uptick you have in processing and memory usage of clients when you serve up compressed content. So that is out of the question.
Of course I could hot-swap drives one at a time with 18TB or 20TB drives. On their disk operating system, you would have to do at least two per volume to start seeing increases in usable disk space.
Or, I could look at new hardware that holds more than 8 drives. Plus, I have a network switch that can easily accommodate two 10GB copper or fiber connections.
I looked at the recommendation spreadsheet (https://docs.google.com/spreadsheets/d/1MfYoJkiwSqCXg8cm5-Ac4oOLPRtCkgUxU0jdj3tmMPc/edit#gid=1274624273) and it looks like the newer Synology NAS lines do not support hardware transcoding, which I think almost puts Synology out of the running, which I think is a big shame given it looks like Synology is the most used brand I see from users in this forum.
Then, I see QNAP has multiple options available. Not too familiar with QNAP running Plex but it looks like it does it and does the hardware transcoding I would want. Something I really like on the QNAP side is they do things like deduplicate, which would be ideal for things like where I have several editions of a movie (Director’s Cut, Theatrical Release, Extended Edition) and I think that dedupe would shrink disk usage among the three MKV files.
So, that being said, I am leaning more towards QNAP and was wondering if any of you with larger deployments had any experience with the larger platform QNAPs or recommendations. There is an option to offload transcoding to a GPU with a NVIDIA card. I don’t have a rack so tower is getting more of my attention.
Thank you to all who respond.
