Last.fm agent not finding correct artist
Hi. I have a band named Jaqueline in my library, but the last.fm agent just matches this as Jacqueline, even though Jaqueline is in their database. What gives? How can this be solved?
This is the proper artist match: https://www.last.fm/music/Jaqueline
The Albums are matching correctly. The problem is the artist page.
They are in a folder called “Jaqueline” sorted like this:
That image and bio is from the artist Jacqueline, not Jaqueline. It’s the wrong match. You have just confirmed the issue yourself.
The rightmost field in my image is the Album artist tag.
Plex matches this artist: https://www.last.fm/music/Jacqueline when it should be this: https://www.last.fm/music/Jaqueline
Both are present in last.fm so why is plex refusing to corectly match the artist?
E: Was unnecesarily rude.
Ok. I’ll try my luck with last.fm then. Thank you for looking into it.
