Last.fm agent not returning correct artist & more
I am having a similar problem as I’ve had previously with another artist with som additions this time. Previous issue: Last.fm agent not finding correct artist
Current issue:
I have two separate artists in my Library, one being TiA, and another being Tia. They are being grouped as one artist in my Library, I’d like to split them up into two artists if possible, but I am not able to figure out how.
Also, the last.fm agent is only returning the artist Tiga, and only Tiga as hit. See attached pictures.
It’s very frustrating when the tags clearly is Tia/TiA. I suspect it’s the same thing happening as with my Jaqueline issue previously. I can’t help but question the reasoning for using last.fm as an agent when their database seems to be a mess.
It should at the very least return this artist: https://www.last.fm/music/Tia instead of https://www.last.fm/music/Tiga
I have attached images of the tags, and the match in the agent.
Yeah, I kinda expected that. Hopefully something improves in the future.
Regarding the other part of my problem, is it possible to split these two artists into separate entries in my library somehow?
Thanks to this and the previous post by @sensei321 i have another example where Plex/Last.fm artist isn’t matching.
I’m trying to match this artist: https://www.last.fm/music/Chai
but plex is returning this artist: https://www.last.fm/music/The+Chariot
previous examples the names were quite similar, but in this case it’s quite obvious they’re different.
All my files have been correctly tagged: Artist/Album Artist all say “Chai”:
but when doing the match i have as only band in the results “The Chariot” showing up with their bio and photo, while the correct “Chai” is nowhere to be found:
I could only fix it by matching with personal media and adding myself Photo/Bio.
Disambiguation between similarly named artsits will improve with the new music stuff.
Plus, you will be able to help improve it, by contributing to MusicBrainz.org
Particularly by putting links into MB to the proper ‘artist’ pages on allmusic.com
