What is the latest PMS verified to work with the aTV3 AND which version of Plexconnect?
Matt
Matt
I am using the latest DVR Beta 3 PMS software with Plexconnect (I believe the latest commit from June) with no issues.
My PMS PC ■■■■ a brick recently and I had to rebuild it last week. When I installed PMS 1.1.4.2757-24ffd60 which DIDN’T work. None of the thumbnails would be generated and the videos would not play, no errors where indicated in the log file. I downgraded to an older version that I found on the internet, PMS 0.9.8.6 0.9.17.3. It worked flawlessly. I would like to know what other people are using also. I was using the Plexconnect commit 3ad6bf5d653ebd3793bfeb7f1abe79a35c8dd9bb, which at this writing is the latest Plexconnect version.
So maybe I need to ask the question a bit differently… What are the latest versions of Plexconnect & PMS that do work with each other?
I had some intermittent issues in the past (I think after a PMS software update) with no thumbnails displayed and no videos playing.
I added both the Apple TV3 and PMS IP addresses in the “List of IP addresses and networks that are allowed without auth”. No issues since then.
PMS > Settings > Network > “List of IP addresses and networks that are allowed without auth”
Thanks jevans04. I update to the latest PMS 1.1.4 and set the “List of networks that are allowed without auth” to include my ATV3 also and everything is working again. I actually just set it to “192.168.1.0/24” so my entire LAN can access it. I have multiple ATV3s that connect to my PMS.
mschlotz you can use the latest version of both PlexConnect and PMS.
Regards.
