Server Version#:
Player Version#: LG TV - WebOS
Starting today the 404 Not Found / Nginx error appears. The WebOS application cannot connect to plex servers to display even a login page. I removed application, added it again, reboot tv, same thing. After loading logo 404 Nginx error is displayed.
Plex works on my computer & iOS apps.
I have similar problems. They appeared on 29/05/25. Until now, everything has been working fine.
LG WebOS v1.4.
Please help me find a solution.
I have verified that DLNA access works, so I will use it for now.
If you need any clarifications or modifications, feel free to let me know.
same problem here, also on LG TV, as of today, 30 May.
Same problem, and only on my LG TV. Ok on android and pc.
Luckily I’m not alone. Hopefully this will be fixed soon.
Server ver.: 1.41.7.9823
I have the same problem on LG TV. I get 404 error if I try to run Plex on TV. Can you please fix this? Thank you!
