Lg 404 not found
Server Version#:
There are problems? I got this error in lg app at this moment.
I also have LG tv and the app shows #404
Same. I have a LG C8 on which the Plex app was working (we used it last night). Just now I tried to bring it up and I see the 404 not found nginx error. I’ve tried it repeatedly and I rebooted the Mini I use to run the Plex Media Server but no luck. I should also point out that when I run Plex (client) on my laptop it shows the PMS running normally.
LG webOS 05.80.35 TV
LG App Store Plex Version 5.0.0
404 Not Found
nginx
sad clown
Hopefully this will be rectified soon.
Knock, knock, you there https://status.plex.tv/ ?
Getting the exact same issue on my PS5 Plex app. :unamused:
404 Not Found
nginx
Same error here also.
404 Not Found
Seems the issue is with how these Plex apps call some sort of authentication/loading page, as the servers themselves appear to be up and accessible from other apps/browsers.
Yes, plus I tried to delete/install the app and it doesn’t load the base app to configure my server IP etc, so it is unrelated to the local server.
I’m also having the same issue on an LG TV, plus I also get the nginx 404 error going to https://app.plex.tv/web/app in the web browser on the PC.
I am also having the same issue. Have tried to reinstall the app as well.
It’s not an app issue, something is down on their end. I am getting a 404 trying to navigate to the web player.
The status just updated https://status.plex.tv
Same error here.
LG CX WebOS.
Same here
Same here
Same here. Tried uninstall/install to no avail.
same
That said, my samsung tv, android app and webui on the same lan are fine and there are a ton of replies here all of a sudden. There is prob an issue across the board on webui.
Same here on LG smart TV.
Uninstall, install changed nothing. Other people I know that have access to Plex are not having problems but I don’t know what app they are using.
I just reinstalled and got in on my lg tv
The only place it didn’t work for me was the LG tv. Seems I got lucky with the website itself. Probably be up soon. Thanks for the link.
Same for me today 3 lg tv same thing. tried to reset tv
uninstall re install
cleared cache same thing.
ask 2 of my friend who use lg tv same thing.
It’s back for me now.
I have 2 LG webOS TVs.
FWIW, this is info from within each app’s settings / about page.
UHD 4K set:
Client Version 5.12.2
Platform 3.9.0
24" set:
Plex for LG 3.13.28
webOS 3.8.0
Software version fragmentation is not pretty.
Glad the Plex team was responsive and hooked it up again.
