Hi all!
I have an issue and can’t tell if this is a problem of my device or Plex. Any help appreciated!
Background story: I’m reading all my (4K) BluRays using MakeMKV. I use ffmpeg to convert the video codec to x265 and keep the best available german and english audio stream (most times DTS[HD]) while dropping the others. Since my television does not support DTS, Plex has to transcode the DTS streams. For 1080p, this works fine, but for some 4K (Harry Potter…) the audio works while the video stream (although TV should support direct play) glitches. According to the net I should transcode the audio to AC3 and add this to my video files.
Transcoding the following audio streams, the english one works fine but the german one does not output anything:
Audio #1
ID in the original source medium : 4352 (0x1100)
Format : DTS XLL X
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Duration : 2 h 21 min
Bit rate mode : Variable
Bit rate : 4 227 kb/s
Channel(s) : 8 channels
Channel(s)_Original : Object Based
ChannelLayout_Original : Object Based
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Delay relative to video : 5 ms
Stream size : 4.18 GiB (6%)
Title : Surround 7.1
Language : English
Default : Yes
Forced : No
Original source medium : Blu-ray
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 24 bits
Compression mode : Lossy
Writing library : Lavc58.91.100 ac3
Language : English
Service kind : Complete Main
Default : No
Forced : No
Audio #3
ID in the original source medium : 4356 (0x1104)
Format : DTS XLL
Codec ID : A_DTS
Bit rate : 2 209 kb/s
Channel layout : C L R Ls Rs LFE
Bit depth : 16 bits
Compression mode : Lossless
Stream size : 2.19 GiB (3%)
Title : Surround 5.1
Language : German
Default : No
Forced : No
Audio #4
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 kb/s
Bit depth : 16 bits
Language : German
Default : No
Forced : No
Server Hardware: Synology DS920+, 20GB RAM
Player Hardware: LG 65GX9LA
Server Version#: 1.21.0.3616
Player Version#: 5.6.1 (and Platform 5.1.1, whatever this means)
I also checked the 1080p (no modification/transcoding of the audio) BluRays - some AC3 audio streams work while other don’t?
Working example: Matrix
ID in the original source medium : 4354 (0x1102)
Format : AC-3
Codec ID : A_AC3
Duration : 2 h 16 min
Bit rate : 640 kb/s
Bit depth : 32 bits
Delay relative to video : -42 ms
Stream size : 624 MiB (6%)
Language : German
Default : Yes
Forced : No
Non-working (no audio) example: Inception
Moderator: Removed duplicate entry
Edit: The audio streams work in VLC media player.
