Libraries and 6TB External Hard Drives
Server Version#:4.1.1
Player Version#:4.1.1.
In my quest to figure out Libraries, I have 5 Questions :
I have a 750GB Hard disk. And about 3TB Used space on external Hard Drives(My Book) .
Questions:
  1. Can I keep the the file on the external HD’s and create Libraries that point to each of the Hard Drives then save the Library?
  2. TV Show I want to play MacGyver 2016, Do I have to point to each file or can I point a directory?
  3. I keep getting the error code after a create the Libraries “unable to save the Library”. if the library is named “Action” How to I change where the library is saved and how do I change it reflect a “savable location” do I change the location of said Library(Action)?.
  4. is a library on file at a time can a folder be in a library?
that’s all folks,
Thank you for reading…
John
1, You can keep your files on the external HDD(s) just as you would on internal HDDs or on a NAS. The only requirement is they mount (/etc/fstab) before PMS starts.
  1. The method you use is to create a “TV” directory containing all your series.
/hdd/
   tv/
     Star Trek (1966)/
       season 1/
         episodes here
      Another Series/
        Season 1/
          Another Series - S01E01 - title.ext
          Another Series - S01E02 - title.ext
Repeat the structure as often as needed
Sections are created and point to the TOP level → /hdd/tv (in this case)
They are a group of series stored in a folder (or multiple folders)
I have
  • /nas/tv, /nas/tv2, (as main tv);
  • /nas/tv3 is for cartoons,
  • /nas/tv4 is for cooking programs
It’s really flexible.
If you need help mounting external drives, there is a how-to (shows you step-by-step)
fstab.txt (1.0 KB)
Here is my fstab file , I really don’t know what to look for, can you help ? John
show me a ‘df’ with all the drives mounted as they currently are (automounter)
I’ll show you how to get the information and, using the guide I wrote, translate that into new lines to add to /etc/ffstab.
Sincerely, these are skills you need to have / learn. We support linux but aren’t equipped to teach it beyond how to use Plex on Linux .
What is a “df?” How do i find it?
df is a command you can use in the Linux shell/terminal.
This particular command will list all drives currently mounted in your system and the used/available space.
How comfortable are you to operate your server on a Linux platform? (meaning no disrespect… I feel people will have a hard time managing their server if they’re not familiar with the host platform and should therefore go with a platform they know how to manage or are willing/capable to learn – based on your questions it seems like you’re not all that familiar with Linux… again, no offense, just an observation)
Answers to Question:
I don’t know the Linux commands. Little by little I am Learning them. I have gone from MS Dos to windows and now Linux. I know that Linux is a “type” (lack of a better word) of Unix. I have a severely underpowered Desktop that I want to put all of my media in a centralized location and play it through Roku boxes scattered throughout the house.
BTW Here is my df, which shows all hard drives , partitions on all drives!
df.txt (2.0 KB)
Let me help you learn the forum.
  1. Linux was created because of what Unix cost back in the day AND that AT&T didn’t have any interest in advancing it. It’s Unix-like. MacOS came directly from Unix and still bears a lot of commonality. Linux has a similar structure and many things are the same but quite a few are linux-unique.
  2. There’s lot of helpful tutorials out there. I would indeed read them and practice them. You’ll find, if you’re willing to put in the time, Linux is easy to learn – but there’s a LOT to learn. (I’ve been doing it for 24 years now and still learn new things here and there)
  3. Here, In the forum, You can copy / paste console text directly into your reply.
the </> (code) key at the top of the reply window will let you paste any text you want.
paste something here
Will look like (which is fixed width and easy to read)
  1. As for the output you sent me.
I see a lot of partitions mounted under /media/media.
Of those, I see drive /dev/sdf has 10 partitions. (mount points listed)
Are you trying to mount each of them?
Also , are you trying to run a Kubernetes cluster ? (I see it’s installed)
They are mounted already.
If i have directory inside a subdirectory
Such as
Action|
           |--1960
                  |--file1.ext
                  |--file2.ext
Will PMS tell you that the library is empty.
Jtm
If i rename the files with {plex.id} {d.format(mm/dd/yyy)} {series}{season: s}
All files are mkv, and will the plex player play this file? John
