Is there any way to search a library with both movie and TV databases, simultaneously ?
if not
Is there any way to change the Library type after creation?
if not
if not
if not
I don’t think you can change the Library Type after it’s created. It only takes a moment to create a new one.
You can change a movie library into a home video library and vice versa.
But you cannot turn a tv show library into a movie library.
